Windows 7 Ultimate 64-bit
Intel Core 2 Duo E8400 8400@ 3Ghz
4GB RAM
Intel G45 Driver v 8.15.10.2189
Intel IDT HD Audio 6.10.6224.7
XBMC Dharma Beta 2
XBMC Hangs just after startup.
I am forced to kill the xbmc process.
Se below for log.
http://pastebin.com/10NCk12u
Is this the first time you've installed XBMC, that is has it never worked, or was it working then stopped working?
The startup looks normal, though I note that the music library scan starts but doesn't finish.
JR
jhsrennie Wrote:Is this the first time you've installed XBMC, that is has it never worked, or was it working then stopped working?
JR
First time after a fresh reboot on my PC XBMC starts.
However, after i started and shuted down XBMC for a while it happends.
desertoak Wrote:First time after a fresh reboot on my PC XBMC starts.
I wonder if xbmc.exe is still running.
There are circumstances under which you can close the XBMC window but xbmc.exe will still be running. For example this can happen if a script is running in the background. When you get this problem use Task Manager to see if xbmc.exe is running.
JR
XBMC.exe is running, but i have to close it because it hangs.
Same problem with Dharma 3.
But i found that it will only hang when i access a menu in xbmc.
Here are a updated log for dharma 3:
http://pastebin.com/hXRWRkG3
Where are you downloading XBMC? And what skin are you using?
TheUni
