2010-10-09, 19:42
I have dharma beta2 and camelot on the same Asrock ION PC. I have them configured the same, i.e. any changes I made to camelot I made to dharma.
Camelot will WOL from a suspend or a full shutdown.
Dharma will not react to a WOL. I know the magic packet is correct as the same program is used in both cases. The change I made to enable WOL was to /etc/rc.local where I added the line
ethtool -s eth0 wol g
just befor the exit 0 in the file.
Is there any way I can check to see if wol g is actually set in the control file for eth0? ethtool does not seem to be in Dharma.
Any Help Appreciated
