2010-10-10, 06:42
I am having some problems with the confluence theme:
http://dl.dropbox.com/u/3817460/Confluence.png
How do you fix this type of problem? I tried another them PM3.HD. It did not have the same rendering issues. Although, there was one image that appeared to have the same problem.
It is installed xbmc-r33778-Dharma_beta2-x86 on a macbook pro running OS X 10.4. The screen resolution is 1440x900.
The xbmc.log file:
http://dl.dropbox.com/u/3817460/xbmc.log
The xbmc.log file:
