Full Version: Tv shows issues
Hi guys,
I have issues with XBMC running on my machine.
The problem been TV shows are not showing up on XBMC unless in file mode.
Now a lot of my TV shows are rips from disc and as of such they look like this in a folder
Two and half men
- Season 1
-- Disc 1
---Audio
---Video
Does XBMC support DVD rips in TV shows?
please help
Cheers
Tim
anyone ... I am really starting to hate XBMC ..
What format is your rips in...ISO, .VOB files, or MKV/AVI/MP4
http://wiki.xbmc.org/index.php?title=XBM...tart_Guide
In short you need to change your directory naming structure, ideally you also need to rip individual episodes and name them correctly.
ok its .vob files
so how do i name them so it picks them up
for example
Two and a half men season 1 disc 1 has 4 episodes on it
How can i make it show in the TV libary?
Hello,
They are telling you that you have to rip each dvd to single episodes. So for instance, your TAAHM S1D1 with 4 episodes would look as such:
Two and a half men - S01E01 - Name of episode 1.avi
Two and a half men - S01E02 - Name of Episode 2.avi
Two and a half men - S01E03 - Name of Eipsode 3.avi
Two and a half men - S01E04 - Name of Episode 4.avi
You don't have to use avi. You can use MKV or mp4 and probably a couple others. But you will need to rip to individual episodes and convert to something. Maybe you can keep the VOB files, but I don't think that you should demux them.
Hope this helps,
Mark
