Using the latest release for Dharma I can't go into the TV menu under settings, when I try to it just doesn't do anything (other than play the click sound).
Axodious Wrote:Using the latest release for Dharma I can't go into the TV menu under settings, when I try to it just doesn't do anything (other than play the click sound).
TV menu is only accessible is you use the PVR branch of xbmc.
ronie Wrote:TV menu is only accessible is you use the PVR branch of xbmc.
Ah, that makes sense. Maybe it could be renamed PVR or something similar cause I thought it was for the TV Shows part of XBMC.
Axodious Wrote:Ah, that makes sense. Maybe it could be renamed PVR or something similar cause I thought it was for the TV Shows part of XBMC.
Funnily enough the TV Shows label is used for the TV Shows part.
This doesn't strike me as terribly confusing
kurai Wrote:Funnily enough the TV Shows label is used for the TV Shows part.
In the "Settings" menu there's options for Video, Pictures, TV and Music. Currently most of the TV Show settings are under Video.
