Full Version: TV show info using aeon skin
hi so im now to xbmc and after reading and watching some tut decided to get started. my movies went on a breeze and the scraper was 99% accurate. my issue is with my tv shows.ive got a master folder set up with about 20 different shows inside their own folder which in turn contain season folders. xbmc picks up only 3 shows thats it! ive tried rescanning and searching for new content put it wont pick anymore up. the strcuture is the same for each series so dont understand why some will work and not others. has anyone got a solution for this issue?
Firstly have a look here, it will help to narrow down your problem, particularly the part about posting a debug log - http://forum.xbmc.org/showthread.php?tid=42708. Also what exactly is your folders/file convention. Likelihood is that file naming is to blame, but until you post a link to your debug log, its only a guess.
