2010-10-11, 01:37
I am running Dharma Beta 2 Live; it looks, plays, and sounds great! However, when using DLNA to play videos from MythTV (MythDora 12), Dharma hangs every time on Restart:
1) Select a video (OTA TV recordings)
2) Play a minute or two
3) Stop playback
4) Select the same video again, press Play
5) Select "Restart from nn:nn" (rather than "Start from beginning")
6) Dharma says "Working", but never starts the movie playback and no longer responds to keystrokes. Pressing the 'Power Off' button on the remote does nothing. It has happened 100% of the time for me; I have tried it perhaps half a dozen times.
If at Step 5 you select 'Restart from Beginning' then everything works fine; the movie plays normally.
If I reboot Dharma after Step 6, then select the same movie and 'Restart from nn:nn", then it hangs again.
Has anyone else seen this? I couldn't find a report of it when I searched, nor could I find an open defect. Would anyone like to see logs? If so, which files? Any suggestions of additional useful experiments that I could run?
3) Stop playback
