2010-10-15, 04:36
Hi all,
Since I updated to beta 3, I made several tests.
Today, in one of these tests, I notice a very poor playback from a particular MKV file: Avatar.2009.1080p.BluRay.DTSMA.x264-FLAWL3SS-HD.mkv. I always use this file for testing, because the bitrate is constantly high and, also, because it have a very beautiful image.
So, this is a reference file to me, since I use it to test the system and to convince friends to build a XBMC box too
Anyway, today I notice in my ION330 box (Asrock 330-HT, running Ubuntu Karmic + beta 3) that this file isn't running smooth as before. It is freezing a lot! Fast freezing (a fraction of second), but too many! Enough to make it unwatchable.
To be sure that nothing is wrong with my particular configuration, I burn a XBMC Live beta 3 CD and boot from it to run this file. Same terrible playback using Live!
Then, my next test was use the Live in my desktop computer, which is much more powerful than the little ION (Q9650 + GeForce GTX 285). Again, the same terrible "grasping" playback.
Beside the lame quality, in all tests the CPU utilization is very low, with shows me that VDPAU is working (but still a suspect).
My next test was install Beta 3 for Windows @ my desktop and try the same file. I was certainly the file will play smooth as always, thinking the problem is related to VDPAU. My mistake: it was a terrible play with a lot of hangs.
So, for sure, the problem isn't VDPAU related since is not limited to Linux OS!
This was the ONLY file I saw with this problem. Again, it was perfect until beta 2. I switch back to Beta 2, on my desktop and my ION box: the same file plays marvelous with beta 2, in Windows and Linux! Not a single quality problem.
Then I start to think: what can be different from this file to any other I've test? I just notice 2 major differences:
Avatar.2009.1080p.BluRay.DTSMA.x264-FLAWL3SS-HD.mkv is the only file with I've found with this problem (so far). The scene @ 1:15:30 to 1:17:00 is my reference: completely unwatchable!
Anyone have this file, and can confirm this issue?
Anyone has notice something similar in any other file?
I'm downloading two other DTS-MA files to test my theory. Will post again as soon I test this 2 files.
Thanks in advance for any input!
- VERY high bitrate for audio and video (means a very large file also, about 24gb);
- Is the only file I have with DTS-MA audio.
