When I installed Beta 3 yesterday my remote failed to work, after some testing I figured out it relate to the new 6.2.32-25 kernel the Beta 3 is installed with.
Can I change what kernel to install some how?
I tried to install the old 6.2.32-24 kernel with apt-get but when I boot on that XBMC won't start...
Help me please =)
PS: Thanks for a kick ass product the XBMC team!
asrock ion330ht ? if so i've heard blacklisting the ir-core module works.
spiff Wrote:asrock ion330ht ? if so i've heard blacklisting the ir-core module works.
Nope it's a MPlay Blast remote and USB reciver. It works in Dharma LIVE Beta 2 with have the 6.2.32-24 kernel.
Works in XBMC Live 9.04 but not in 9.11 =\
So can I some how edit the XBMC install to run 6.2.32-24 kernel?
well that's simple, apt-get install the old kernel, apt-get remove the new one.
spiff Wrote:well that's simple, apt-get install the old kernel, apt-get remove the new one.
Yes, I did that but then XBMC won't start... do I have to reinstall the Nvidia drivers or something to work with the old kernel?
hrm i thought we had the dkms added. if that's not the case you have to rebuild the kernel module yeah.
Can you please let me know how to get the asrock ion330ht working? How do I blacklist the ir-core module?
Thank you so much! Kind of a command line newb
Thank you spiff I will try tonight!
spiff Wrote:hrm i thought we had the dkms added. if that's not the case you have to rebuild the kernel module yeah.
Yepp that did the trick. I downloaded the Nvidia driver, reinstalled and now everything is perfect =) Boots a hell of a lot faster then the old 9.04 I have been running, Nice!
