2010-10-15, 15:54
i got a problem with a file. Specs:
Video:
720p h264
Audio:
aac 2.0(ger) + 5.1(eng)
Subtitle:
subt
The file is merged with mkvmerge 4.2 and header removal compression was on.
It does play well using windows 7 and VLC or XBMC(Beta3) but on my Linux Ion System the XBMC Beta 2 and 3 just dont play the file. The screen freezes and XBMC eats all my memory (1,75GB for System).
The preview image works btw.
I cut the first 100MB of the file with dd - could anyone with some tech knowledge check that out and tell me whats wrong?
http://gatekeeper.shadow-node.net/Test.mkv
THX!
Video:
720p h264
Audio:
Subtitle:
subt
THX!
