2010-10-16, 03:25
I know the sticky says not to ask about this stuff here, and I really do want to obey ... but where do I go to ask about build issues? I HAVE done builds before successfully (many times) but for some reason the last few days after I update from svn my build compiles cleanly but won't run (using VS2008 on Win7 64 - DirectX build)...
I can build and run a debug build against my (old) build home, but when I do a release build and install it it fails with:
I have been trying for 2 days to get this working... Nothing in the xbmc log - it faults before it even gets a chance to write to the log. I assume since I can run against my debug build home it is a library issue, but I don't have a clue which library because everything seems to be fine in the actual compile logs. If I install Dharma beta 3 it runs fine, but if I compile any head revisions as a release exe (revision 3477, but I have tried about 10 or 12 since yesterday) and copy it to the install folder it just dies when I run it (no modifications - just straight from head). I also tried doing a complete buildinstall and installing that, but same fault.
Anybody wanna throw me a bone? I was working on a patch and did an svn update 2 days ago and ever since Ive been stuck... Is it just me?
Faulting application name: XBMC.exe, version: 10.5.0.0, time stamp: 0x4cb8f5b0
Faulting module name: XBMC.exe, version: 10.5.0.0, time stamp: 0x4cb8f5b0
Exception code: 0xc0000417
Fault offset: 0x00617f56
Faulting process id: 0x678
Faulting application start time: 0x01cb6cce859023f0
Faulting application path: C:\Program Files (x86)\XBMC\XBMC.exe
Faulting module path: C:\Program Files (x86)\XBMC\XBMC.exe
Report Id: c3432710-d8c1-11df-bd92-58b0358cdef8
