Full Version: Export library database metadata information to Excel?
Hi, I am looking for a good way to get some statistics out of my XBMC library. I am mainly looking for the TV library, but the movies would be a plus. I would like info like: how many episodes, total gigabytes, resolution, number of seasons, runtime, etc...
Is this possible. In the past i have basically scanned all my file locations for video files using a directory printer and was able to reduce all the data via a pivot table into Show, Season, Number of Episodes, and Size.
Is this possible? Is there a tool already to do this?
I do not mind just getting raw data as I am used to excel and working with millions of cells of info into nice, easy to deal with charts/pivot tables.
Thanks,
Jeff
Well you can just install http://www.ch-werner.de/sqliteodbc/ to have odbc access to XBMC database from excel then do whatever you want with data Smile
But as i know there's no file size information in the database Smile
Ok, thanks, installed that..... now what?
anyone with any additional information?
Not sure if theyll provide all the info youre after but try EmberMM or XWMM
