Full Version: smb problem
hello all ,
i have weird problem , using xbmc dharma beta 1 i could connect to my windows 7 shared folder with smb option ,
since then i installed beta 2 and 3 , and now when trying to connect to my shared folder with smb option it keep asking me the user/pass .
hope to get this solved .
using macbook pro with mac os x 10.6.4
the only way i can connect to my shared folder is from mac os x
and then going to volumes from xbmc .
thx in advance .
moshelog
uninstall windows live messenger from your computer on windows 7
lapinou Wrote:uninstall windows live messenger from your computer on windows 7
Why does this fix it?
How did you know?
I'm having the same problem today, and it was driving me nuts.
lapinou thx alot
working good now .
problem solved .
