Full Version: Skin related help [SKIN AEON MQ 2]
Hey everyone, I have small problem which i could use some help with,
Im not %100 on how to describe what i mean so i took a screenshot to try and explain better,
http://img534.imageshack.us/img534/4917/85309036.png
(link because of the size)
Well as you can see from that pic on every movie i have those 2 empty box's, Now iv been looking it up on here and it seems there for screens (from what i can tell) However on my sytem they don't show and i can't see any options as to turn them on.
If anyone could tell me how to activate those that would be awsome.
Kind regards
//JoelP53 Cool
Joelp53 Wrote:Hey everyone, I have small problem which i could use some help with,
Kind regards
//JoelP53 Cool
you need those image in your movie folder (Movie/extrathumbs/thumb1.jpg and so on)
can be created with ember media manager for example.
So would i name a thumb for say...
The Matrix
And create a folder called extrathumbs in my movie folder?
or is it a folder for each film so it would be:
The Matrix/extrathumbs/thumb1.jpg ?
Also could you explain how to do this with Ember please?
Edit:nvm it seems i can't use this feature:
Requirement: Extrathumbs can only be used if you have all your movies in their own, separate folder.
Thanks for the quick reply anyways phil65
