Full Version: Subtitle preference change in Dharma Beta3
Hi all, I have a question regarding the new Dharma Beta 3.
I was using Dharma Beta 2 under windows and today I changed to Dharma Beta 3 to give it a try (I wasn`t having any problem). It seems that the order of preference when you have multiple subtitles have changed. When you have both internal subtitles (I mean inside the video container) and external subtitles (in the form of a .srt file) XBMC used to prefer the external ones. Now it seems that the internal subs are prefered. Is it any way to change this back?
Thanks in advance,
Mariano
One more thing, I can change the subtitle being used in the audio settings window to the .srt file and it works, but even after I use the "set as default for all movies" option, it still prefer the embeeded ones.
I guess I`ll go back to Beta2... :-(
Mariano
doesn't happen to me..
regression. already fixed.
Thank you very much for checking this issue. :-)
Have a nice day!
