2010-10-18, 15:44
My XBMC installation is not using the VDPAU acceleration despite of the option being selected in the settings menu.
This is what I have done so far:
1. Installed XBMC from XBMCLive Dharma beta 3 to my pc (Intel Core2 E4600 - nVidia 8600GT 256MB - 1GB RAM)
2. Installed the latest NVIDIA drivers (260.19.12) as described in this post:
3. Turn ON the "Use VDPAU acceleration" setting
But I can see that the movie is not smooth.
Infact when I press 'o' during a playback of a BluRay backup (H264 1080p24): movie I see:
It looks like it's not using the VDPAU acceleration.
What I am supposed to do to make this working?
Maybe the installation instructions in step 2 were wrong somewhere?
Should I ever done the step 2, or the NVIDIA drivers were already installed?
Just to make a test , I have setup on the same PC a Windows installation with XBMC.
And when I press 'o' during the same bluray movie, I see:
So this means that the card supports hardware acceleration but for some reason the LINUX version is not picking it up.
Any suggestion?
Login - xbmc
password - xbmc or whatever you used at install
sudo apt-get update
sudo apt-get install wget
sudo apt-get install build-essential linux-headers-`uname -r`
download the NVIDIA driver
wget ftp://download.nvidia.com/XFree86/Linux-x86/260.19.12/NVIDIA-Linux-x86-260.19.12.run
sudo telinit 1
cd /home/xbmc
sudo sh NVIDIA-Linux-x86-260.19.12.run (say no to the first question then yes to the rest)
dc: ff-h264
CPU 0: 80% CPU 1: 84%
dc: ff-h264-dxva2
CPU average: 20%
Any suggestion?
