2010-10-18, 15:45
Hello folks,
I have read all threads about issues related to dependencies and unfortunately I could not find a clear solution. While for some worked a certain procedure to reinstall XBMC, for others didn't.
After having a nice working Dharma xbmc with lucid I had some changes to samba, then removed all files related to samba and reinstalled it but XBMC did not worked anymore.
When I try to reinstall, I have:
Then:
reboot, added the SVN PPA, then when I try again to install XBMC I have the same error.
When I add the stable PPA I could successfully install the XBMC 9.11. I have removed it since I need to have Dharma and back to square one.
I have removed again the PPAs and everything I could find about XBMC then I have tried:
Then I tried through dpkg, downloaded all files from SVN PPA, then:
I don't know how to use the "force" option.
And I don't understand, I have removed all files xbmc related based on search and purge and autoremove commands and I still get error dependencies about xbmc and confluence.
I have no idea how to fix it. I wish to get back to install Dharma XBMC. Could anyone please help me?
The following packages have unmet dependencies:
xbmc: Depends: xbmc-data (= 2:10.00~svn34731-lucid1) but it is not going to be installed
Depends: xbmc-skin-confluence (= 2:10.00~svn34731-lucid1) but it is not going to be installed
E: Broken packages
sudo apt-get purge xbmc
then
sudo nano /etc/apt/sources.list
and removed the xbmc SVN PPA's
Then searched for "xbmc" and removed all files and folders related.
Rebuild your list index by:
sudo update-apt-xapian-index
sudo apt-get dist-upgrade
then
sudo apt-get -f install
mkdir svn_r34731
- moved all downloaded fle to this folder, then
cd svn_r34731
then
sudo dpkg -i xbmc*.deb
and I got:
dpkg: dependency problems prevent configuration of xbmc-skin-confluence:
xbmc-skin-confluence depends on xbmc-data (= 2:10.00~svn34731-lucid1); however:
Package xbmc-data is not configured yet.
dpkg: error processing xbmc-skin-confluence (--install):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of xbmc-standalone:
xbmc-standalone depends on xbmc-data (= 2:10.00~svn34731-lucid1); however:
xbmc-standalone depends on xbmc-skin-confluence (= 2:10.00~svn34731-lucid1); however:
Package xbmc-skin-confluence is not configured yet.
dpkg: error processing xbmc-standalone (--install):
Errors were encountered while processing:
xbmc-dbg_10.00~svn34731-lucid1_i386.deb
xbmc-live_10.00~svn34731-lucid1_i386.deb
xbmc-bin
xbmc-data
xbmc-eventclients-j2me
xbmc-eventclients-wiiremote
xbmc-standalone
xbmc
