Full Version: Play .iso files,
Hello!
I have used xbmc for a while now and I can't get it to play .iso files (dvd movies on a file).
I have tried the repo-version and I have now installed the latest dharma from svn (https://xbmc.svn.sourceforge.net/svnroot...hes/Dharma, Revision: 34852)
Running Ubuntu 10.04.1, and my setup is done by following the guide XBMCbuntu, except that I now have installed the svn version.
I have installed restricted-extras and run /usr/share/doc/libdvdread4/install-css.sh
uname -a
Linux MaShi 2.6.32-25-server #44-Ubuntu SMP Fri Sep 17 21:13:39 UTC 2010 x86_64 GNU/Linux
Here's the log file:
http://pastebin.com/sscLkkhg
Thanks for your time!
Phasip
- Edit, Sorry I submitted before finishing the title.
your iso files are not dvd isos. you probably have a joliet enabled filesystem in them. dvd iso's are hybrid udf 1.02 / iso level 1.
Is there any test-iso that I can try and do you know of any tool that will convert my iso-s to the right format, or maybe a way to make xbmc play theese too?
mkisofs -dvd-video
Now I just have to figure how to convert bluray .iso files to a playable format.
