Full Version: runtime info not displayed for tv shows with <streamdetails> in nfo
When using ember and scan metadata enabled for TV shows, I noticed that the runtime field when bringing up the show info isnt populated.
If this info is not included in the nfo file, then the runtime field gets populated.
an example of an nfo with included info:
http://pastebin.com/CMvg6bxT
if you remove the <streamdetails> section, then runtime is displayed.
Confluence doesnt actually show the runtime information in the show information window, but Transparancy does. Don't think this is a skin specific issue and hopefully that not a bad assumption on my part.
