Full Version: \ key error - makes screen go small
I am using XBMC live Dharma beta 2. When i hit the "\" key on the keyboard the screen goes to a quarter scren with a small X. I can't get it back unless i plug in a mouse and click the small screen.
I was wondering if there is any way to disable this function?
hitting the \ key again should restore it....
Its a feature, not an error Big Grin
it has been disabled with --standalone (which live runs) for final.
spiff Wrote:it has been disabled with --standalone (which live runs) for final.
[off topic] Since there seem to be quite some questions about xbmc live and you're a dev (who seems to know about 'live'): do you know where I can get info on the inner workings of the Live CD? I'd like to know how to log in on the prompt and if xbmc uses pulseaudio...
I know its based on Ubuntu 9.10 Mobile ed. but...
xbmcuser01 Wrote:[off topic] Since there seem to be quite some questions about xbmc live and you're a dev (who seems to know about 'live'): do you know where I can get info on the inner workings of the Live CD? I'd like to know how to log in on the prompt and if xbmc uses pulseaudio...
ssh into your box, or CRTL+ALT+F2 for a terminal
and no to pulse
uhm, the entire source is in svn. you can build your own if you want using tools/XBMCLive/SDK/build.sh.
currently it's based on lucid. it was never based on the mobile edition, it's custom tailored. we do not use pulseaudio.
spiff Wrote:uhm, the entire source is in svn. you can build your own if you want using tools/XBMCLive/SDK/build.sh.
Thanks! I read one some Wiki it was based on 'buntu mobile. Never trust Wikipedia, ha ha ("kiks in open door").
I had coincidently pressed the \ key as well on beta2 my screen went small, the \ key did not bring it full screen it was like it lost focus of xbmc. my mouse didn't show up I had no way to getting fullscreen a reboot didn't work either... but my remote had a fullscreen button which saved the day for me.
-=Jason=-
