2010-10-22, 14:03
I'm rather confused what the 'requirements' are for mysql libraries to work on multiple machines, I have two Revos of similar spec running beta3 and a mysql server running on my file server.
In the past i've always used fstab to mount my fileserver shares as /~/tv etc (~ = home folder) and then defined them in sources.xml. Then i manually set the content type in xbmc and the scraper goes to work - I tried this method with the advancedsettings.xml for mysql storage - the first machine seemed to fill up the database fine.
I then cleaned the library on my second machine and added advancedsettings.xml and rebooted ... to my suprise it started scraping its own local database with no noticable 'error' in xbmc.log ...
I read somewhere (can't find it now) that you need to have similar folder names on your sources? What are the rules on sources.xml and local folders along with mysql libraries?
So confused....
So confused....
