Full Version: [LINUX] HOW-TO create a XBMC server for diskless PXE network booting clients
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
dushmaniac Wrote:there's no easy way to do that with the scripts I provide.
Too bad!
I run this script.
sudo mount -o bind /dev /var/lib/xbmc-diskless/target/dev
sudo mount -t proc none /var/lib/xbmc-diskless/target/proc
sudo mount -t sysfs none /var/lib/xbmc-diskless/target/sys
sudo mount -t devpts none /var/lib/xbmc-diskless/target/dev/pts
sudo cat << EOF > /var/lib/xbmc-diskless/target/usr/sbin/policy-rc.d
#!/bin/sh
exit 101
EOF
sudo chmod +x /var/lib/xbmc-diskless/target/usr/sbin/policy-rc.d
sudo chroot /var/lib/xbmc-diskless/target
Then I run: apt-get install xorg gdm gnome-core
apt-get wants to delete xbmc-diskless-client
Removing xbmc-diskless-client ...
No diversion `diversion of /usr/bin/update-notifier by xbmc-diskless', none removed
No diversion `diversion of /usr/bin/nm-applet by xbmc-diskless', none removed
update-rc.d: /etc/init.d/ltsp-client-core: file does not exist
dpkg: error processing xbmc-diskless-client (--remove):
subprocess installed post-removal script returned error exit status 1
Processing triggers for ureadahead ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Can I delete xbmc-diskless-client or must it be there? How to remove if I can..?
Or how do I get the gnome desktop with wine, firefox, spotify and all necessary.
if you delete the xbmc-diskless-client, your client won't boot anymore (as diskless client) because it'll delete the initramfs script needed to boot.
if you want to run a full ubuntu client instead of just xbmc, you should be using ltsp or something like that, not this package.
dushmaniac Wrote:if you delete the xbmc-diskless-client, your client won't boot anymore (as diskless client) because it'll delete the initramfs script needed to boot.
I can google it ..
Good stuff otherwise, shame is not enough for me. Smile
I was researching on how to do this with Windows, and it turns out you can boot a windows 7 image using iSCSI? I have experience using nlite/vlite and I think this would be the perfect solution for me (netflix, bitstreaming, etc using ATI hardware). I don't have experience with iSCSI however. Can anyone knowledgeable point me to a good resource? Is there any special hardware required, besides a server?
http://www.thogan.com/site2/archives/10
bump
no special hardware requirements, except for the clients that need network card / bios that supports pxe.
there are lots of manuals around for windows and iscsi. just google it.
Morning
I seem to be having an issue. I am using a DD-WRT router as the DHCP server and I believe it is working correctly, but when i boot I just get a file not found after the DHCP request. I was digging around trying to figure it out and i saw in your checklist to check a file /var/lib/tftpboot/pxelinux.cfg/default but that file isnt on my system
[email protected]:/var/lib/xbmc-diskless# cat /var/lib/tftpboot/pxelinux.cfg/default
cat: /var/lib/tftpboot/pxelinux.cfg/default: No such file or directory
[email protected]:/var/lib/tftpboot# ls -la /var/lib/tftpboot/
total 13948
drwxr-xr-x  4 root root     4096 2011-02-19 01:04 .
drwxr-xr-x 75 root root     4096 2011-02-18 12:14 ..
-rw-r--r--  1 root root 10203243 2011-02-19 12:47 initrd.img
drwxr-xr-x  2 root root     4096 2010-04-26 02:55 ltsp
-rw-r--r--  1 root root  4037888 2011-02-19 12:47 vmlinuz
drwxr-xr-x  2 root root     4096 2011-02-18 12:14 xbmc-netboot
I can see the tftp service is running:
[email protected]:/var/lib/xbmc-diskless# ps waux | grep tftp
root      5833  0.0  0.0  14796   332 ?        Ss   Feb18   0:00 /usr/sbin/in.tftpd --listen --user tftp --address 0.0.0.0:69 --secure /var/lib/tftpboot
root     24890  0.0  0.0   7432   912 pts/8    S+   13:11   0:00 grep tftp
And i dont see a pxelinux.cfg anywhere on my system
[email protected]:/var/lib/tftpboot# updatedb
[email protected]:/var/lib/tftpboot# locate pxelinux
/usr/lib/syslinux/pxelinux.0
/usr/share/doc/syslinux/pxelinux.txt.gz
/var/lib/xbmc-diskless/target/usr/lib/syslinux/pxelinux.0
/var/lib/xbmc-diskless/target/usr/share/doc/syslinux/pxelinux.txt.gz
Any suggestions?
Cheers!
create a directory /var/lib/tftpboot/pxelinux.cfg and create a file "default" in that dir.
put this in the file:
DEFAULT vmlinuz ro initrd=initrd.img nbdroot=x.x.x.x nbdport=2000 xbmcdir=nfs=x.x.x.x:/var/lib/xbmc-diskless/overlay xbmc=autostart quiet splash
replace x.x.x.x by your server's ip
Cheers mang. That worked. Sooo its a x64 install? I thought it would have been 32bit. Was testing on my eeepc and it wouldnt boot because its a x64 version and that CPU is not.
Anyway to do a 32 bit? All i did was type lucid in the install distro thingy
Hmmm ok maybe i understand a bit more. The pxelinux file is x64 because the server is x64. So how/where can i get a different pxelinux.0. I didnt see any created when i made the image
Ok lol im wrong! I used a different laptop and was able to boot and it is a 64bit install. Why is that? was that because the server it was made of is 64bit? Anyway to make a 32bit image on a 64bit server?
Cheers!
nope, not possible (yet).
OK, well is it possible then to create the image in lets say OpenBox running 32bit Ubuntu, and just copy it back over to said server?
sure. the image can be copied to any server you like. you just can't create an image for another arch yet.
Quote:[email protected]:~$ sudo apt-get update
Ign http://ppa.launchpad.net maverick Release.gpg
Ign http://ppa.launchpad.net/lars-odenkamp/x...ss/ubuntu/ maverick/main Translation-en
Ign http://ppa.launchpad.net/lars-odenkamp/x...ss/ubuntu/ maverick/main Translation-en_US
Ign http://ppa.launchpad.net/lars-opdenkamp/...es/ubuntu/ maverick/main Translation-en
Ign http://ppa.launchpad.net/lars-opdenkamp/...es/ubuntu/ maverick/main Translation-en_US
Hit http://ppa.launchpad.net maverick Release.gpg
Ign http://ppa.launchpad.net/lars-opdenkamp/...ss/ubuntu/ maverick/main Translation-en
Ign http://ppa.launchpad.net/lars-opdenkamp/...ss/ubuntu/ maverick/main Translation-en_US
Hit http://us.archive.ubuntu.com maverick Release.gpg
Ign http://us.archive.ubuntu.com/ubuntu/ maverick/main Translation-en
Ign http://us.archive.ubuntu.com/ubuntu/ maverick/main Translation-en_US
Ign http://ppa.launchpad.net maverick/main Sources
Ign http://ppa.launchpad.net maverick/main i386 Packages
Ign http://us.archive.ubuntu.com/ubuntu/ maverick/multiverse Translation-en
Ign http://us.archive.ubuntu.com/ubuntu/ maverick/multiverse Translation-en_US
Ign http://us.archive.ubuntu.com/ubuntu/ maverick/restricted Translation-en
Ign http://us.archive.ubuntu.com/ubuntu/ maverick/restricted Translation-en_US
Ign http://us.archive.ubuntu.com/ubuntu/ maverick/universe Translation-en
Ign http://us.archive.ubuntu.com/ubuntu/ maverick/universe Translation-en_US
Hit http://us.archive.ubuntu.com maverick-updates Release.gpg
Ign http://us.archive.ubuntu.com/ubuntu/ maverick-updates/main Translation-en
Ign http://us.archive.ubuntu.com/ubuntu/ maverick-updates/main Translation-en_US
Ign http://us.archive.ubuntu.com/ubuntu/ maverick-updates/multiverse Translation-en
Ign http://us.archive.ubuntu.com/ubuntu/ maverick-updates/multiverse Translation-en_US
Ign http://us.archive.ubuntu.com/ubuntu/ maverick-updates/restricted Translation-en
Hit http://ppa.launchpad.net maverick/main Sources
Ign http://us.archive.ubuntu.com/ubuntu/ maverick-updates/restricted Translation-en_US
Ign http://us.archive.ubuntu.com/ubuntu/ maverick-updates/universe Translation-en
Ign http://us.archive.ubuntu.com/ubuntu/ maverick-updates/universe Translation-en_US
Hit http://security.ubuntu.com maverick-security Release.gpg
Hit http://ppa.launchpad.net maverick/main i386 Packages
Ign http://security.ubuntu.com/ubuntu/ maverick-security/main Translation-en
Ign http://security.ubuntu.com/ubuntu/ maverick-security/main Translation-en_US
Err http://ppa.launchpad.net maverick/main Sources
404 Not Found
Err http://ppa.launchpad.net maverick/main i386 Packages
404 Not Found
404 Not Found
Hit http://us.archive.ubuntu.com maverick/main Sources
Hit http://us.archive.ubuntu.com maverick/restricted Sources
Hit http://us.archive.ubuntu.com maverick/universe Sources
Hit http://us.archive.ubuntu.com maverick/multiverse Sources
Hit http://us.archive.ubuntu.com maverick/main i386 Packages
Hit http://us.archive.ubuntu.com maverick/restricted i386 Packages
Hit http://us.archive.ubuntu.com maverick/universe i386 Packages
Hit http://us.archive.ubuntu.com maverick/multiverse i386 Packages
404 Not Found
Hit http://extras.ubuntu.com maverick Release.gpg
Ign http://extras.ubuntu.com/ubuntu/ maverick/main Translation-en
Hit http://us.archive.ubuntu.com maverick-updates/main Sources
Hit http://us.archive.ubuntu.com maverick-updates/restricted Sources
Hit http://us.archive.ubuntu.com maverick-updates/universe Sources
Hit http://us.archive.ubuntu.com maverick-updates/multiverse Sources
Hit http://us.archive.ubuntu.com maverick-updates/main i386 Packages
Hit http://us.archive.ubuntu.com maverick-updates/restricted i386 Packages
Hit http://us.archive.ubuntu.com maverick-updates/universe i386 Packages
Hit http://us.archive.ubuntu.com maverick-updates/multiverse i386 Packages
Ign http://security.ubuntu.com/ubuntu/ maverick-security/multiverse Translation-en
Ign http://security.ubuntu.com/ubuntu/ maverick-security/multiverse Translation-en_US
Ign http://security.ubuntu.com/ubuntu/ maverick-security/restricted Translation-en
Ign http://security.ubuntu.com/ubuntu/ maverick-security/restricted Translation-en_US
Ign http://security.ubuntu.com/ubuntu/ maverick-security/universe Translation-en
Ign http://security.ubuntu.com/ubuntu/ maverick-security/universe Translation-en_US
Ign http://extras.ubuntu.com/ubuntu/ maverick/main Translation-en_US
Hit http://security.ubuntu.com maverick-security/main Sources
Hit http://extras.ubuntu.com maverick/main Sources
Hit http://extras.ubuntu.com maverick/main i386 Packages
Hit http://security.ubuntu.com maverick-security/restricted Sources
Hit http://security.ubuntu.com maverick-security/universe Sources
Hit http://security.ubuntu.com maverick-security/multiverse Sources
Hit http://security.ubuntu.com maverick-security/main i386 Packages
Hit http://security.ubuntu.com maverick-security/restricted i386 Packages
Hit http://security.ubuntu.com maverick-security/universe i386 Packages
Hit http://security.ubuntu.com maverick-security/multiverse i386 Packages
W: Failed to fetch http://ppa.launchpad.net/lars-odenkamp/x...Sources.gz 404 Not Found
W: Failed to fetch http://ppa.launchpad.net/lars-odenkamp/x...ackages.gz 404 Not Found
W: Failed to fetch http://ppa.launchpad.net/lars-opdenkamp/...Sources.gz 404 Not Found
W: Failed to fetch http://ppa.launchpad.net/lars-opdenkamp/...ackages.gz 404 Not Found
E: Some index files failed to download, they have been ignored, or old ones used instead.
I believe my problem starts here, because it cant download all the files?
and creating an image fails...
Anything i can do to fix it`?
