Full Version: [LINUX] HOW-TO create a XBMC server for diskless PXE network booting clients
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
i've got everything running now.
one problem still remains: my mce remote controls doesn't work.
i need to run dpkg-reconfigure lirc on the client zu get it working. but how do i do this in the image?
you could do it in the image, but you shouldn't really.
just boot the client, ssh to it and dpkg-reconfigure the package. reboot to see if the changes were persisted. if not, something outside /etc got modified and you'll have to do it in the image anyway.
Hello,
I have installed this on a new Ubunto 10.10 installation. The whole installation went without problems, and
sudo xbmc-diskless.sh check
gives me yes to all.
But when I try to boot a client, I get TFTP-error file not found. (klik)
I have no idea where to start searching what the problem is. Can you point me to some places to check?
the check command doesn't check for the right tftp config at the moment.
you probably have the wrong path set in your dhcp server's config.
for isc dhcpd it's:
subnet 192.168.64.0 netmask 255.255.192.0 {
        range 192.168.90.100 192.168.90.125;
        next-server 192.168.64.1;
        filename "/xbmc-netboot/pxelinux.0";
fill in your own addresses ofcourse
This is my complete dhcpd.conf.
ddns-update-style none;
max-lease-time 7200;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.0.255;
option routers 192.168.0.1;
option domain-name-servers 192.168.0.1;
subnet 192.168.0.0 netmask 255.255.255.0 {
range 192.168.0.100 192.168.0.200;
        next-server 192.168.0.10;
log-facility local7;
I've added the lines already, but still the same problem.
and does pxelinux.0 exist at /var/lib/tftpboot/xbmc-netboot/pxelinux.0 on the machine with ip 192.168.0.10?
No, the directory /var/lib/tftpboot/xbmc-netboot is empty.
But there is an pxelinux.0 file in /usr/lib/syslinux/ Should I copy it over to the xbmc-netboot directory?
hmm that's odd, I thougt I had the script copy those files. did you use "install" in the menu?
if you did, copy the file over. also check if a directory pxelinux.cfg is present in /var/lib/tftpboot. if not, create and and create a file called "default" in it. put this in that file:
DEFAULT vmlinuz ro initrd=initrd.img nbdroot=192.168.64.1 nbdport=2000 xbmcdir=nfs=192.168.64.1:/var/lib/xbmc-diskless/overlay xbmc=autostart quiet splash
replace the ip by the ip of your server.
I'm sure initrd.img and vmlinuz are copied by the "install" so those should be present in /var/lib/tftpboot too.
initrd.img and vmlinuz are there. But pxelinux.cfg directory wasn't. So i created it, and I created the default file.
Now the system boots a little bit furhter, but then it fails again. Now with the message: Unable to locate configuration file
Where should that file be??
I guess that's before you see any files (kernel, initrd) being loaded?
what dhcp server are you using?
I think it's not prepending xbmc-netboot/ to each path. Doing that yourself will probably solve it.
so
DEFAULT xbmc-netboot/vmlinuz ro initrd=xbmc-netboot/initrd.img nbdroot=192.168.64.1 nbdport=2000 xbmcdir=nfs=192.168.64.1:/var/lib/xbmc-diskless/overlay xbmc=autostart quiet splash
Just before the Unable to locate configuration file message, I got a message with TFTP prefix: /xbmc-netboot/
So I think that wouln't the problem. But to be sure i've added the path to the file. But still the same message. No
I also found the folloing in daemon.log:
Jan  4 20:23:49 john-MS-7596 in.tftpd[2247]: tftp: client does not accept options
Jan  4 20:27:14 john-MS-7596 in.tftpd[2266]: tftp: client does not accept options
Jan  4 20:29:03 john-MS-7596 in.tftpd[2282]: tftp: client does not accept options
Jan  4 20:35:05 john-MS-7596 in.tftpd[2390]: tftp: client does not accept options
Jan  4 20:40:26 john-MS-7596 in.tftpd[2419]: tftp: client does not accept options
Jan  4 20:45:47 john-MS-7596 in.tftpd[2476]: tftp: client does not accept options
Jan  4 20:51:09 john-MS-7596 in.tftpd[2550]: tftp: client does not accept options
Jan  4 20:57:51 john-MS-7596 in.tftpd[2630]: tftp: client does not accept options
Jan  4 21:03:12 john-MS-7596 in.tftpd[2651]: tftp: client does not accept options
can you access the file from another machine using a tftp client supplying the same path as your diskless installation does (or should do)?
Hey,
Thanks for this really nice thing, but I'm having trouble getting it to run on a HTPC with a ATI graphicscard (onboard HD3200).
I could see in the Xorg.0.log, that it didn't find ATI, VESA and a third module, can't remember the name of it. I discovered by googleling around that I can fix this by installing the fglrx package.
Finally XBMC started fine, but only the first time. The second time I got an OpenGL error (XBMC needs hardware accelerated OpenGL rendering. Install a appropriate graphics driver). By trial and error I discovered that, if I remove the folder in the overlay directory for the specific HTPC I could start it again, but again only the first time. So apparently some settings are stored there, which is causing the error, but I can't find out what.
I get this error when I start the XBMC for the second time in the Xorg.0.log:
[email protected]:~$ cat /var/log/Xorg.0.log |grep EE
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(II) Loading extension MIT-SCREEN-SAVER
(EE) AIGLX error: failed to load OpenGL driver
(EE) AIGLX: reverting to software rendering
(II) XKB: generating xkmfile /tmp/server-F8D9B4EE1D9075AF4B1C23C75362EE93E14954A0.xkm
Do you have any ideas how to solve this. I'm quite new at this linux thing, so please don't use to many linuxgeek words Smile
dushmaniac Wrote:can you access the file from another machine using a tftp client supplying the same path as your diskless installation does (or should do)?
I have never used TFTP before. I have installed the TFTP client on windows vista. What command do I have to execute to do that?
When I try: TFTP 192.168.0.10 GET initrd.img I get a time-out error.
@JohnPollaert:
it looks like your diskless client can reach the server, or you wouldn't see any log entries.
it should be something like
TFTP 192.168.0.10 GET /xbmc-netboot/initrd.img
@RavenDK:
stuff like that isn't really easy to do yourself if you don't know anything about linux as you stated in your post. you'd have to install a package in the image.
if someone can tell me what the package is that is needed for those cards, I'll include it.
