Hi All,
The title says it all. Is there any way to get xbmc to behave with a composite screen, it works perfectly with composite off, but I use composite on most of the time..
I am running gnome with compiz installed and using gtk window themes on archlinux.
Cheers,
Bernie
This is probably outside our hands, I run compiz on my desktop (and many I would bet) which I develop on. I have no problems running xbmc.
I'd suggest checking different versions of compiz or check your drivers, I'm fairly certain its outside xbmc space.
Cheers,
Tobias
topfs2 Wrote:This is probably outside our hands, I run compiz on my desktop (and many I would bet) which I develop on. I have no problems running xbmc.
Cheers,
Tobias
I am using the latest catalyst drivers to go with xorg-server 1.9.0, can anyone verify that combo works ..
Cheers,
Bernie
Black&white means the shader doesn't work correctly, please post a debug log.
Ok, here is the gist of the log file, I don't know how to attach the complete thing:
Quote:--------------------------------------------------------
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Mon Oct 25 09:25:23 NZDT 2010
XBMC Options:
Arch: i686
Kernel: Linux 2.6.35-ARCH #1 SMP PREEMPT Wed Sep 29 07:17:20 UTC 2010
Release:
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/bmentink/core
############# END STACK TRACE ###############
################# LOG FILE ##################
09:24:22 T:3049273216 M:2889957376 ERROR: Failed to create common scripts symlink.
09:24:22 T:3049273216 M:2890108928 NOTICE: -----------------------------------------------------------------------
09:24:22 T:3049273216 M:2890108928 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Oct 14 2010 (SVN:-ARCH)
09:24:22 T:3049273216 M:2890108928 NOTICE: special://xbmc/ is mapped to: /opt/xbmc
09:24:22 T:3049273216 M:2890108928 NOTICE: special://masterprofile/ is mapped to: /home/bmentink/.xbmc/userdata
09:24:22 T:3049273216 M:2890108928 NOTICE: special://home/ is mapped to: /home/bmentink/.xbmc
09:24:22 T:3049273216 M:2890108928 NOTICE: special://temp/ is mapped to: /home/bmentink/.xbmc/temp
09:24:22 T:3049273216 M:2890108928 NOTICE: The executable running is: /opt/xbmc/xbmc.bin
09:24:22 T:3049273216 M:2890108928 NOTICE: Log File is located: /home/bmentink/.xbmc/temp/xbmc.log
09:24:22 T:3049273216 M:2889826304 NOTICE: Setup SDL
09:24:22 T:3049273216 M:2888708096 NOTICE: load settings...
09:24:22 T:3049273216 M:2888708096 NOTICE: special://profile/ is mapped to: special://masterprofile/
09:24:22 T:3049273216 M:2888708096 NOTICE: loading special://masterprofile/guisettings.xml
09:24:22 T:3049273216 M:2888859648 NOTICE: Getting hardware information now...
09:24:22 T:3049273216 M:2888859648 NOTICE: Checking resolution 11
09:24:22 T:3049273216 M:2888859648 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
09:24:22 T:3049273216 M:2888859648 NOTICE: Loaded playercorefactory configuration
09:24:22 T:3049273216 M:2888859648 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
09:24:22 T:3049273216 M:2888859648 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
09:24:22 T:3049273216 M:2888859648 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
09:24:22 T:3049273216 M:2888859648 NOTICE: Default DVD Player: dvdplayer
09:24:22 T:3049273216 M:2888859648 NOTICE: Default Video Player: dvdplayer
09:24:22 T:3049273216 M:2888859648 NOTICE: Default Audio Player: paplayer
09:24:22 T:3049273216 M:2888859648 NOTICE: special://masterprofile/sources.xml
09:24:22 T:3049273216 M:2864218112 NOTICE: Using fbConfig[0]
09:24:23 T:3049273216 M:2861797376 NOTICE: GL_VENDOR = ATI Technologies Inc.
09:24:23 T:3049273216 M:2861797376 NOTICE: GL_RENDERER = ATI Mobility Radeon HD 4500 Series
09:24:23 T:3049273216 M:2861797376 NOTICE: GL_VERSION = 3.3.10243 Compatibility Profile Context
09:24:23 T:3049273216 M:2861797376 NOTICE: GL_EXTENSIONS = GL_AMDX_debug_output GL_AMDX_vertex_shader_tessellator GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_draw_buffers_blend GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_sample_positions GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_texture_cube_map_array GL_AMD_texture_texture4 GL_AMD_vertex_shader_tessellator GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_buffer_object_rgb32 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
09:24:23 T:3049273216 M:2861309952 NOTICE: HAL: Generating global device list
09:24:23 T:3049273216 M:2861309952 NOTICE: start dvd mediatype detection
09:24:23 T:3049273216 M:2861309952 NOTICE: initializing playlistplayer
09:24:23 T:3049273216 M:2861309952 NOTICE: DONE initializing playlistplayer
09:24:23 T:3049273216 M:2861309952 NOTICE: load default skin:[Confluence]
09:24:24 T:3049273216 M:2858364928 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
09:24:24 T:3049273216 M:2858364928 ERROR: Can't open the database 09:25:21 T:3049273216 M:2836975616 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
09:25:21 T:3049273216 M:2836975616 NOTICE: Storing total System Uptime
09:25:21 T:3049273216 M:2836975616 NOTICE: Saving settings
********* more of the same *********
I removed my .xbmc directory, now the log shows this ... but same b&w screen.
Quote:21:21:02 T:2978306928 M:2484539392 NOTICE: -->Python Interpreter Initialized<--
21:21:02 T:3051194240 M:2483396608 WARNING: Unable to determine Linux distribution
21:21:45 T:2978306928 M:2479353856 WARNING: Unable to determine Linux distribution
21:21:46 T:3051194240 M:2478522368 NOTICE: DVDPlayer: Opening: htsp://192.168.1.5:9982/tags/0/1.ts
21:21:46 T:3051194240 M:2478522368 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
21:21:46 T:2929376112 M:2478522368 NOTICE: Creating InputStream
21:21:46 T:2929376112 M:2478743552 NOTICE: Creating Demuxer
21:21:46 T:2929376112 M:2478743552 NOTICE: Opening video stream: 0 source: 256
21:21:46 T:2929376112 M:2478743552 NOTICE: Creating video codec with codec id: 2
21:21:46 T:2929376112 M:2478743552 NOTICE: Creating video thread
21:21:46 T:2929376112 M:2478743552 NOTICE: Opening audio stream: 1 source: 256
21:21:46 T:2929376112 M:2478743552 NOTICE: Finding audio codec for: 86016
21:21:46 T:2929376112 M:2478743552 NOTICE: Creating audio thread
21:21:46 T:2929376112 M:2478743552 WARNING: Process - Could not detect frame rate for: htsp://192.168.1.5:9982/tags/0/1.ts. Using default of 25.000 fps for conversion of any commercial break frame markers to times.
21:21:46 T:2912590704 M:2478616576 NOTICE: running thread: CDVDPlayerAudio:rocess()
21:21:46 T:2920983408 M:2476150784 NOTICE: running thread: video_thread
21:21:47 T:2912590704 M:2475495424 NOTICE: Creating audio device with codec id: 86016, channels: 2, sample rate: 48000, no pass-through
21:21:47 T:2912590704 M:2475569152 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:47 T:2912590704 M:2475495424 ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
21:21:47 T:2912590704 M:2475495424 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:47 T:2912590704 M:2475487232 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:47 T:2912590704 M:2475413504 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:47 T:2912590704 M:2475339776 ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
21:21:47 T:2912590704 M:2475339776 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:48 T:2912590704 M:2475634688 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:48 T:2920983408 M:2475126784 NOTICE: fps: 25.000000, pwidth: 720, pheight: 576, dwidth: 1050, dheight: 576
21:21:48 T:2920983408 M:2475126784 NOTICE: Display resolution DESKTOP : 1600x900 @ 60.00 - Full Screen (12)
21:21:48 T:2912590704 M:2473435136 ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
21:21:48 T:3051194240 M:2473656320 NOTICE: Using GL_TEXTURE_2D
21:21:48 T:3051194240 M:2473656320 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
21:21:48 T:3051194240 M:2470010880 NOTICE: GL: NPOT texture support detected
21:21:48 T:2912590704 M:2468319232 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:48 T:2912590704 M:2468319232 ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
21:21:48 T:2912590704 M:2468245504 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:50 T:2912590704 M:2467500032 ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
21:21:50 T:2912590704 M:2467500032 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:50 T:2912590704 M:2467794944 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:50 T:2912590704 M:2467692544 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:50 T:2912590704 M:2467545088 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:51 T:2912590704 M:2467823616 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:51 T:2912590704 M:2467676160 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:52 T:2912590704 M:2468380672 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:53 T:2912590704 M:2468159488 ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
21:21:53 T:2912590704 M:2468159488 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:53 T:2912590704 M:2468085760 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:53 T:2912590704 M:2468339712 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:54 T:2912590704 M:2468601856 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:55 T:2912590704 M:2468675584 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:55 T:2912590704 M:2468519936 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:55 T:2912590704 M:2468593664 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:56 T:2912590704 M:2468519936 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:56 T:2912590704 M:2468593664 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:56 T:2912590704 M:2468425728 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:56 T:2978306928 M:2466627584 WARNING: Unable to determine Linux distribution
21:21:57 T:2912590704 M:2460319744 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:57 T:2978306928 M:2460422144 WARNING: Unable to determine Linux distribution
21:21:58 T:2912590704 M:2460422144 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:58 T:2912590704 M:2460790784 ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
21:21:58 T:2912590704 M:2460790784 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
21:21:58 T:2912590704 M:2460782592 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
Nothing wrong there, you can test with setting render method to basic shaders(arb) or to software.
Thanks, setting to basic shaders did the trick. I wonder why I don't have advanced shading support anymore since the upgrade to catalyst and xorg-server ..
Edit: glxinfo shows: OpenGL shading language version string: 3.30
Cheers,
Bernie
Well, you still do, it just isn't working.
