Full Version: [RELEASE] IRFree (IRFree.com) Plugin
BROKEN - this plugin will not be maintained anymore
Use RlsBB.com Plugin instead!
Current version: 0.2.2
Features:
This plugin scrapes posts from IRFree.com and presents them as directory items. By selecting a post the link gets added to JDownloader.
Screenshots:
Where to find:
You can download it from anarchintosh's unofficial add-on repository (category "Program Add-ons").
You can launch it after the installation from "PROGRAMS".
Changelog:
Quote:Version 0.2.2
* Removed obsolete (=all) filehoster: hotfile.com, filesonic.com, fileserve.com, upfile.in & wupload.com
* New supported filehoster: turbobit.net & extabit.com
Version 0.2.1
* Ignore duplicate filehoster links
Version 0.2.0
* Refactoring (Using now the library DDLScraper)
* Added search function
* Fixed problem with posts, that have no image. Sometimes XBMC didn't react anymore
* New supported filehoster: upfile.in, wupload.com
* Fixed problems with the new website design
Version 0.1.2
* Fixed problems with scraping category 'All' and specific movies
* Changed plugin logo, due to the new website design
* Show progress dialog while fetching posts
* Added new setting to hide all subcategories
* Fixed problem with 'refused connection' due to multiple fetches
Version 0.1.1
Version 0.1.0
* Initial release
Planned:
- improve release info scraping for movies and episodes (size, quality, etc.)
- tv-shows: mark episodes, that you already have
- tv-shows: show only tv-shows, that you already have
Credits:
Thanks to "TheCollective"! This plugin is based on the YouTube plugin
Please give me feedback in this thread.
good good good Big Grin
i'll try that !
Very cool! Working well.
[b]Version 0.1.1[/b]
Would it be possible to set it up so it passes the link to other torrent client (utorrent for example)?
As far as I know, there are only one-click-hoster links at irfree.com. So, no!
But if there were any and the torrent-client offers an api to add torrent, it would be possible.
Hi...
Worderfull add jus amazing everyting from the coach... just a question... Irfree just have fileserver links and jdownloader do not take the re-captcha so we need to enter manually and that make bad all the thing.. is there any way to handle it....
Thanks..
I'm sorry, I can not help you with this issue, since I usually use a premium account, so I don't have to enter a captcha...
[b]version 0.1.2[/b]
From now on this plugin will be available via anarchintosh's unofficial addon repository Nod
[b]Version 0.2.0[/b]
[b]Version 0.2.1[/b]
version 0.2.2
Is this still working? I installed it but I get nothing scraped- no links\images etc. Please advise
(2013-04-16, 20:11)xdamageincx Wrote: [ -> ]Is this still working? I installed it but I get nothing scraped- no links\images etc. Please advise
I looked into this and decided that it's not worth maintaining this plugin anymore, since irfree.com only provides SecureUpload links anymore.
Due to that this plugin is now officially marked as broken!
There will be a new release of RlsBB Plugin soon. I recommend to use that plugin instead.
