Full Version: update nvidia drivers
Hi all,
I am trying to update the nvidia drivers to 260.19.04, but I can't find a tutorial for that in this forum.
I have now the 195 drivers
I tried:
apt-get update
apt-get upgrade
but after the update/upgrade the drivers are still 195.
I am using xbmcfreak LiveCD 10.00 beta 3 Vanilla.
Anyone can help?
thanks
Try the packages from the x swat repository.Been using these for many months now on several machines without any problems:
https://launchpad.net/~ubuntu-x-swat/+archive/x-updates
cejstrup Wrote:Try the packages from the x swat repository.Been using these for many months now on several machines without any problems:
Thanks for the tip.
I have added the repo but then how can I install the package (sorry I am new to Linux...) ?:confused2:
how did you add the repo? did you do a sudo apt-get update afterwards?
Hannes The Hun Wrote:how did you add the repo? did you do a sudo apt-get update afterwards?
I did it now and it worked!
Sorry for my bad linux knowledge...
But thanks for solving my problem.
