2011-01-17, 00:33
I have an extract of the debug log for you:
This time the display showed: 23:27:01 - but the time was not refreshed, so was stuck to this output... Maybe the debug.log is helpful (remark: I have shorten the debug.log with "(...)").
Thanks and best regards,
Markus
16.01.2011 23:26:59 [GUI] Settings successfully applied to the GUI
16.01.2011 23:26:59 [GUI] Setting up iMON
16.01.2011 23:26:59 [GUI] Setting up XBMC connection to 127.0.0.1:8080
16.01.2011 23:26:59 [GUI] Auto-connecting to XBMC at startup
16.01.2011 23:26:59 [XBMC] XbmcJsonRpcConnection.IsAlive
16.01.2011 23:26:59 [GUI] Asynchronous starting to connect with XBMC
16.01.2011 23:26:59 [XBMC] Opening a connection to XBMC
16.01.2011 23:26:59 [XBMC] XbmcJsonRpc.Ping()
16.01.2011 23:26:59 [XBMC] Calling JSON RPC method "JSONRPC.Ping"...
16.01.2011 23:26:59 [GUI] Minimizing application to tray at startup
16.01.2011 23:27:00 [XBMC] JSON RPC call: {
"jsonrpc": "2.0",
"method": "JSONRPC.Ping",
"id": 1
16.01.2011 23:27:00 [XBMC] JSON RPC response: {
"id" : 1,
"jsonrpc" : "2.0",
"result" : "pong"
16.01.2011 23:27:00 [XBMC] XbmcPlayer.GetActivePlayers()
16.01.2011 23:27:00 [XBMC] Calling JSON RPC method "Player.GetActivePlayers"...
"jsonrpc": "2.0",
"method": "Player.GetActivePlayers",
"id": 2
"id" : 2,
"jsonrpc" : "2.0",
"result" : {
"audio" : false,
"picture" : false,
"video" : false
16.01.2011 23:27:00 [XBMC Handler] Start working
16.01.2011 23:27:00 [XBMC] XbmcSystem.GetInfoLabels(System.Time(hh), System.Time(mm), System.Time(ss))
16.01.2011 23:27:00 [XBMC] Calling JSON RPC method "System.GetInfoLabels"...
"jsonrpc": "2.0",
"method": "System.GetInfoLabels",
"params": [
"System.Time(hh)",
"System.Time(mm)",
"System.Time(ss)"
"id": 3
"id" : 3,
"jsonrpc" : "2.0",
"result" : {
"System.Time(hh)" : "23",
"System.Time(mm)" : "27",
"System.Time(ss)" : "00"
16.01.2011 23:27:00 [XBMC Handler] Update
16.01.2011 23:27:00 [XBMC] XbmcJsonRpcConnection.IsAlive
16.01.2011 23:27:00 [XBMC] XbmcJsonRpc.Ping()
16.01.2011 23:27:00 [XBMC] Calling JSON RPC method "JSONRPC.Ping"...
"jsonrpc": "2.0",
"id": 4
"id" : 4,
"jsonrpc" : "2.0",
"result" : "pong"
16.01.2011 23:27:00 [GUI] Connection with XBMC established
16.01.2011 23:27:00 [XBMC] XbmcGeneral.BuildVersion
16.01.2011 23:27:00 [XBMC] XbmcSystem.GetInfoLabel(System.BuildVersion)
"jsonrpc": "2.0",
"params": [
"System.BuildVersion"
"id": 5
16.01.2011 23:27:00 [XBMC Handler] Updating icons
16.01.2011 23:27:00 [XBMC Handler] Displaying Idle
"id" : 5,
"jsonrpc" : "2.0",
"result" : {
"System.BuildVersion" : "10.0 r35647"
16.01.2011 23:27:00 [XBMC] XbmcGeneral.BuildDate
16.01.2011 23:27:00 [XBMC] XbmcSystem.GetInfoLabel(System.BuildDate)
"jsonrpc": "2.0",
"params": [
"System.BuildDate"
"id": 6
"id" : 6,
"jsonrpc" : "2.0",
"result" : {
"System.BuildDate" : "Dec 17 2010"
16.01.2011 23:27:00 [GUI] Initializing iMON
16.01.2011 23:27:00 [iMON] IMON_Display_Init(66024, 37428)
16.01.2011 23:27:00 [iMON] Message received: PluginSuccess(2)
16.01.2011 23:27:00 [iMON] State changed
16.01.2011 23:27:00 [GUI] iMON LCD initialized
16.01.2011 23:27:00 [Display Handler] Start working
16.01.2011 23:27:00 [iMON] IMON_Display_SetLcdSpeakerIcon(10000000, 10000000)
16.01.2011 23:27:00 [iMON] IMON_Display_SetLcdSpeakerIcon(10000001, 10000001)
16.01.2011 23:27:00 [iMON] IMON_Display_SetLcdSpeakerIcon(10000011, 10000011)
16.01.2011 23:27:00 [iMON] IMON_Display_SetLcdSpeakerIcon(10001011, 10001011)
16.01.2011 23:27:00 [iMON] IMON_Display_SetLcdSpeakerIcon(10101011, 10101011)
16.01.2011 23:27:00 [iMON] IMON_Display_SetLcdSpeakerIcon(11101011, 11101011)
16.01.2011 23:27:01 [Display Handler] Setting text to "23:27:01"
16.01.2011 23:27:01 [Display Handler] LCD.SetText: 23:27:01
16.01.2011 23:27:01 [iMON] IMON_Display_SetLcdText(23:27:01)
16.01.2011 23:27:02 [Display Handler] Setting text to "23:27:02"
16.01.2011 23:27:02 [Display Handler] LCD.SetText: 23:27:02
16.01.2011 23:27:02 [iMON] IMON_Display_SetLcdText(23:27:02)
16.01.2011 23:27:03 [Display Handler] Setting text to "23:27:03"
16.01.2011 23:27:03 [Display Handler] LCD.SetText: 23:27:03
16.01.2011 23:27:03 [iMON] IMON_Display_SetLcdText(23:27:03)
16.01.2011 23:27:04 [Display Handler] Setting text to "23:27:04"
16.01.2011 23:27:04 [Display Handler] LCD.SetText: 23:27:04
16.01.2011 23:27:04 [iMON] IMON_Display_SetLcdText(23:27:04)
16.01.2011 23:27:05 [Display Handler] Setting text to "23:27:05"
16.01.2011 23:27:05 [Display Handler] LCD.SetText: 23:27:05
16.01.2011 23:27:05 [iMON] IMON_Display_SetLcdText(23:27:05)
16.01.2011 23:27:40 [Display Handler] Setting text to "23:27:40"
16.01.2011 23:27:40 [Display Handler] LCD.SetText: 23:27:40
16.01.2011 23:27:40 [iMON] IMON_Display_SetLcdText(23:27:40)
16.01.2011 23:27:40 [XBMC] JSON RPC Announcement received: {
"jsonrpc" : "2.0",
"method" : "Announcement",
"params" : {
"message" : "ApplicationStop",
"sender" : "xbmc"
16.01.2011 23:27:40 [XBMC] Closing the connection
16.01.2011 23:27:40 [GUI] XBMC has been closed
16.01.2011 23:27:40 [XBMC Handler] Update
16.01.2011 23:27:40 [Display Handler] Setting text to "XBMC Shutdown"
16.01.2011 23:27:40 [Display Handler] LCD.SetText: XBMC Shutdown
16.01.2011 23:27:40 [XBMC Handler] Stop working
16.01.2011 23:27:40 [iMON] IMON_Display_SetLcdText(XBMC Shutdown)
16.01.2011 23:27:41 [Display Handler] Setting text to "23:27:41"
16.01.2011 23:27:41 [Display Handler] LCD.SetText: 23:27:41
16.01.2011 23:27:41 [iMON] IMON_Display_SetLcdText(23:27:41)
16.01.2011 23:27:42 [Display Handler] Setting text to "23:27:42"
16.01.2011 23:27:42 [Display Handler] LCD.SetText: 23:27:42
16.01.2011 23:27:42 [iMON] IMON_Display_SetLcdText(23:27:42)
16.01.2011 23:27:42 [GUI] Uninitializing iMON
16.01.2011 23:27:42 [iMON] LCD.Reset()
16.01.2011 23:27:42 [iMON] IMON_Display_SetLcdText()
16.01.2011 23:27:43 [iMON] LCD.Icons.Reset()
16.01.2011 23:27:43 [iMON] IMON_Display_SetLcdAllIcons(False)
16.01.2011 23:27:43 [iMON] IMON_Display_Uninit()
16.01.2011 23:27:43 [iMON] State changed
16.01.2011 23:27:43 [GUI] iMON uninitialized
16.01.2011 23:27:43 [Display Handler] Stop working
16.01.2011 23:27:43 [Display Handler] Setting text to "23:27:43"
16.01.2011 23:27:47 [Display Handler] Setting text to "23:27:47"
16.01.2011 23:27:48 [GUI] Trying to auto-connect with XBMC
16.01.2011 23:27:48 [XBMC] XbmcJsonRpcConnection.IsAlive
16.01.2011 23:27:48 [GUI] Asynchronous starting to connect with XBMC
16.01.2011 23:27:48 [XBMC] Opening a connection to XBMC
16.01.2011 23:27:48 [Display Handler] Setting text to "23:27:48"
16.01.2011 23:27:49 [GUI] Connection with XBMC failed
16.01.2011 23:27:49 [Display Handler] Setting text to "23:27:49"
16.01.2011 23:27:53 [Display Handler] Setting text to "23:27:53"
16.01.2011 23:27:54 [GUI] Trying to auto-connect with XBMC
16.01.2011 23:27:54 [XBMC] XbmcJsonRpcConnection.IsAlive
16.01.2011 23:27:54 [GUI] Asynchronous starting to connect with XBMC
16.01.2011 23:27:54 [XBMC] Opening a connection to XBMC
16.01.2011 23:27:55 [Display Handler] Setting text to "23:27:54"
16.01.2011 23:27:55 [GUI] Connection with XBMC failed
16.01.2011 23:27:56 [Display Handler] Setting text to "23:27:55"
16.01.2011 23:28:00 [Display Handler] Setting text to "23:27:59"
16.01.2011 23:28:00 [GUI] Trying to auto-connect with XBMC
16.01.2011 23:28:00 [XBMC] XbmcJsonRpcConnection.IsAlive
16.01.2011 23:28:00 [GUI] Asynchronous starting to connect with XBMC
16.01.2011 23:28:00 [XBMC] Opening a connection to XBMC
16.01.2011 23:28:01 [Display Handler] Setting text to "23:28:00"
16.01.2011 23:28:01 [GUI] Connection with XBMC failed
16.01.2011 23:28:02 [Display Handler] Setting text to "23:28:01"
16.01.2011 23:28:05 [Display Handler] Setting text to "23:28:04"
16.01.2011 23:28:06 [GUI] Trying to auto-connect with XBMC
16.01.2011 23:28:06 [XBMC] XbmcJsonRpcConnection.IsAlive
16.01.2011 23:28:06 [GUI] Asynchronous starting to connect with XBMC
16.01.2011 23:28:06 [XBMC] Opening a connection to XBMC
16.01.2011 23:28:06 [Display Handler] Setting text to "23:28:05"
Markus
