Ok, i forgot to implement some methods in the JSON Lib for Eden, i will fix that
Thanks a lot for this one!
It's working very well with eden.
The only problem I have is that it displays only the episode name (instead of Show: SxxExx - Name) when I watch a tv show.
Cheers
ok, i used the Pre-EDEN DLL like suggested...
now it finally doesnt crash anymore.
XBMC-on-IMON is connected using port 8080 like before...
only thing is, on my LCD screen, nothing shows up what so ever...
movie name doesnt appear when playing.
XBMC name doesnt appear on startup..
like i said, nothing shows up, period!
whats left to do?
thx
cdenfert wrote:
Quote:However it is a specific version for VFD, I removed the code of the LCD.
So this version will not work with your LCD screen.
Cheers
oh no, can that code be placed back?
some of us have LCD'S
thx
No sorry, because LCD and vfd Works differently , and i can't test since i don't have a LCD . But you could try the pre eden dll with the other version of xbmconimon. Let me know if it works.
Waven Wrote:Thanks a lot for this one!
Cheers
Thanks for your feedback
I identified the problem, I think I can fix it for tomorrow.
Hi cdenfert thanks for your code!
I can see a problem in the progressbar, since it's made using weird characters instead of blocks in my VFD. aprat of that and the prob with the TV series mentioned before the software works with no problem :-)
well, looks like it works!!
i tried your updated pre-eden dll and walla!!
thanks man!
dtorner Wrote:Hi cdenfert thanks for your code!
Which character are wrong in the progress bar?
cdenfert Wrote:Which character are wrong in the progress bar?
well the progressbar at 0% looks like :
then the states of the block changes to:
The last one is not exactly like the char I posted (▲
, is a double up arrow with a little triangle on top of another, Makes sense?
dtorner Wrote:well the progressbar at 0% looks like :
The last one is not exactly like the char I posted (▲, is a double up arrow with a little triangle on top of another, Makes sense?
Strange it looks like you don't have the same VFD charset as mine.
the good character are [·············] when empty, and the blocks have 4 states
Yep, seem that my Display is using the next charset (I got the picture from imon board):
