Full Version: XBMC on iMON Display (LCD / VFD) for Windows
Does it still break when you pause->continue?
NorDemoniac: What version and what problem exactly do you mean?
Hi, kudo's on this project! Finally making the screen useful Smile
I'm trying to get the screen to work on a friends' computer, but I'm getting an error.
I pastebinned the error.log here.
I would appreciate your help in this.
Machine details:
iMon hardware: Antec Fusion Remote
iMon software: 8.12.1202
XbmcOnImonDisplay-v0.1.4.0
OS: Windows 7 Ultimate x64
XBMC: 11.0 Eden beta 3
@BlackMan:
is there a way to make your version of XBMC on iMON to work
with NET FRAMEWORK v3.5?
no matter what i try, latest FRAMEWORK v4 wont install on my Windows 7 Ultimate x64.
hence, i cant use your version of XBMC on iMON.
please lemme now, thanks!
Windows 7 should come with .NET Framework 4 pre-installed so you don't need to and can't install it again.
eskro: I have sent a PM to you.
Wuolennaj: Which version of XbmcOniMon are you using?
Montellese Wrote:Windows 7 should come with .NET Framework 4 pre-installed so you don't need to and can't install it again.
im under Windows 7 Ultimate x64 and it never came with .NET Framework 4 pre-installed.
can Service Pack 1 do the trick? as i dont have SP1 installed.
It's 3.5.1 that is bundled with Windows 7.
What is the error when you install .Net 4 ?
Exe (D:\0b3b20d7468cb126793c149a\Windows6.1-KB958488-v6001-x64.msu) failed with 0x643 - Fatal error during installation. .
PerformOperation on exe returned exit code 1603 (translates to HRESULT = 0x643)
Action complete
OnFailureBehavior for this item is to Rollback.
Action: Performing actions on all Items
Action complete
Action complete
Final Result: Installation failed with error code: (0x00000643), "Fatal error during installation. " (Elapsed time: 0 00:00:14).
This is a common error, please check :
http://support.microsoft.com/kb/976982/en-us that should help you correct this. (Even if you don't install via Windows update).
tried already, both methods didn't work...
i really tried everything :/
Even the cleanup client that uninstall all .Net then just install the .Net 4 ?
I see this error quite often and this one have corrected in all cases.
i tried all possible suggestions...
no clean up tool works..
its crazy..
i think its a win7 x64 ultimate thing...
I'm under x64 ultimate on 2 pc here and no problem at all Smile
One of you program must be locking the .Net no luck, because more and more programs will use .Net 4.
Tolriq Wrote:I'm under x64 ultimate on 2 pc here and no problem at all Smile
yeah well, if my grand'ma had a framwork issue like i do,
was he she supposed to do? lol
in then END, this is a HTPC, i dont need tons of apps.
by the time i need framework4, windows8 will be out,
or win7 will come pre-installed with it.
i'll act accordingly when the time comes.
one strange thing tho, in my Add/remove programs,
i dont see .NET 3.5 nor .NET 2.0 ,,,,
thats weird because .NET DETECTIVE says i got both installed...
