Full Version: XBMC on iMON Display (LCD / VFD) for Windows
For me,
I use Frodo Alpha 4 and all is ok with my imon VFD (OrigenAE M10).
Anyone has experience qith this display?
(2012-12-21, 10:54)polarrys Wrote: [ -> ]parslej,
Did you try this version :
http://forum.xbmc.org/showthread.php?tid...pid1009329
Tried that but doesnt work to me...
Friend of mine (who knows C#) finally helped me to make it working
DId some small corrections in code and now works to me with VFD (Nox case) and XBMC Frodo RC2
Here is compiled version for those interested...
http://www.filedropper.com/imon-on-xbmc-by-parslej
I had some time to look into the matter
(2012-12-29, 04:24)Elizab7eth Wrote: [ -> ]I had some time to look into the matter
Pictures are not displayed to me ?
(2012-12-29, 11:32)parslej Wrote: [ -> ]
Nor me...
parslej, this work fine for me.
Thermaltake DH 202 LCD display
Thanks Rofl
So far, so good Parslej. (iMon LCD - Zalman HD 503 Case) Smile
(2012-12-30, 22:23)gibxxi Wrote: [ -> ]So far, so good Parslej. (iMon LCD - Zalman HD 503 Case) Smile
Good to hear. Do not forget then add +1 to my reputation Wink
Good new !!!
My OrigenAE case has a very simple Imon VFD (not icon). It's just a 2 lines display.
Which XbmconImon must use with my case?
Thx
Done Parslej, and thanks. Smile
(2012-12-31, 12:02)polarrys Wrote: [ -> ]My OrigenAE case has a very simple Imon VFD (not icon). It's just a 2 lines display.
Have you tried my version few posts above?
Quick question about this software...
I use the standard iMon software so I don't get much info from the display other than XBMC (stop). However it does offer great remote support. I have it recognizing Microsoft remote inputs and I can even assign button presses to keyboard buttons so I don't have to mess with keymaps in xbmc. So my question is, is this XBMCiMon software a modified version of iMon's software or is it totally different. Can I install this version and still assign keyboard buttons to the remote?
(2012-12-31, 16:42)htpc guy Wrote: [ -> ]Quick question about this software...
I think this software just replaces the "Frontview" portion of iMon for XBMC but don;t quote me on that (unless I'm correct of course).
This software works as addon to standard iMon software
IMon manufacturer shared API allowing other applications display info on VFD and this is used by XBMC on IMON software.
(so standard iMon *must* be still installed on your box)
I also very like this experimental feature of xbmcOnIMon when VFD displays XBMC menu items so I cannot easily navigate eg MUSIC without turning on TV
READ that:
https://github.com/BlackMan82/xbmc-on-im...ter/README
