Hi Folks,
I am using the parslej version and its running fine so far on my Origen case -imon display. However, it only displays one line of information and scrolling does not work. Any chance to get the second line of information to work or even the scrolling?
THX in advance,
Walter
So I've updated this to the latest version and it works, but only if I run XBMC and then manually click connect in XMC On Imon. I've got the settings to check automatically every 5secs to detect when XBMC is running but it never seems to connect. I've had XBMC running hours and the screen just remains on the Imon app.
Any ideas? It worked fine before on a previous version with the same settings.
I've updated this to the latest version and it worked but after watching some stuff its got crash.
the fast way to crash this is to watch a movie, skip to the middle, stop, then play again using xbmc option ''play from XX:XX" and boom, crash..
any idea?
Hi everyone...
I'm running v0.1.9.5 and it seems to work ok, except I don't have icons or a progress bar. I get the movie name and key press etc.
In config the show icons are ticked. The show progress is ticked but greyed out
btw, frodo rc3 with vfd.
Any help or ideas appreciated.
thanks
(2013-01-09, 22:24)kcarson Wrote: [ -> ]Hi everyone...
thanks
What kind of icons are you expecting on your VFD? AFAIK, icons are only on LCDs...
(2013-01-10, 01:43)tomer953 Wrote: [ -> ]http://code.google.com/p/xbmc-on-imon/downloads/list
DO NOT use, only testing versions (the REAL repo without parslej's modifications is at
github).
(2013-01-10, 01:43)tomer953 Wrote: [ -> ]https://sourceforge.net/projects/xbmc-on-imon/
DO NOT use, working only with XBMC 10.
Not sure what I was expecting. I assumed there were little codec icons at the side. Hard to see as they don't light up but there's something there.
There is a line along the bottom that I had assumed was the progress bar.
Any way to test rhe imon to light it all up?
@parslej: thanks for your version, works as expected on my antec fusion remote black, rep+1
(2013-01-11, 16:36)sergiocos Wrote: [ -> ]@parslej: thanks for your version, works as expected on my antec fusion remote black, rep+1
Happy to hear
Win7 32bit , frodo rc3, antec micro fusion
works to me too.
Ladies and gents,
Have been reading and reading and cant seen to find the answer, so any help will be greatly appriciated.
I really wanna get this working with my Moneual 320, is that possible.
Can anybody help me I've an Antec Fusion & i've never been able to get the display to work properly when playing movies & Tv shows.The screen will just display XBMC Stop.
I've Frodo rc3 installed & iMON Manager Version 8.12.1202
I've tried the workaround in the first post cange the port & username & password but all i get is can't connect
Bettz1,
first, disable imon manager Media Information about XBMC, it just don't work, (always show XBMC STOP). after you disable this, restrat XBMC and you should see nothing.
then,
Install this:
http://www.filedropper.com/imon-on-xbmc-by-parslej
and config it like you want, (statup with windows, and IP and port etc)
Good luck
(2013-01-13, 20:07)tomer953 Wrote: [ -> ]Bettz1,
then,
Install this:
Good luck
Typical the website goes down just as i was about to dl the file
I've disabled imon manager via Option - Plug-in Mode - unticked the box (is this correct?)
Or would it be Imon Utilities - Frontview - Run Frontview when Imon Starts tick Never?
