2013-02-12, 06:19
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
2013-02-14, 10:15
Hi to all
I'm a new user and my english is not very clear.
Recently i assembly a new mediacenter with antec case (fusion 350) and install XBMC and XBMC on iMon to control front display.
All work but I try to see the code to insert ti view "spectrum analyzer" on display when i playng music.
I tried here
http://wiki.xbmc.org/index.php?title=Userdata/LCD.xml
and here
http://wiki.xbmc.org/index.php?title=InfoLabels
but I do not seem to see the correct string.
Any ideas?
Andrea
I tried here
and here
Any ideas?
Andrea
2013-02-15, 00:54
XBMConiMon does not have graphic equalizer display support. This is/was only available via the iMon software drivers, which no longer works with XBMC (Frodo and up). It also didn't work for WASAPI output since that output type takes exclusive control of the device, and thus Windows (and hence iMon) cannot see the sound level data.
So the only way to get this working is to use the "Media Information Tab" in iMon Manager, and select the checkbox for "XBMC" with an Eden version of XBMC installed, and the single configurable sound device set to a DirectSound Output and no XBMConiMon installed or loaded. Also, you have to erase the username/password for the XBMC webserver as iMon does not give you the ability to configure these values.
Otherwise, use XBMConiMon + XBMC (Frodo) and disable any iMon integration with XBMC in their own drivers, and forego any display of a spectrum analyzer / graphic equalizer display.
2013-02-15, 08:58
gibxxi, thanks a lot
Fortunately is only a my intention of customization.
i will stay with only title information
2013-02-17, 15:39
please help me out here. I am a newbie at xbmc. I followed your instructions (README) but when I try to connect I get: “Cannot connect to XBMC at 127.0.0.1:8080.
OS is Windows 7 64 bit, Hardware is SilverStone Grandia GD02S-MT, IMON Software is iMon Manager 8.12.1202, your software is v0.1.4.0 Beta.
Do I need to install JSON or imonDisplayAPI separately or something?
Any help would be much appreciated!
2013-02-17, 16:47
The "8080" port should be the one that's set in the XBMC settings (GUI) and is port 80 by default.
The second port setting (in XBMConiMon) I have mine configured as, for TCP Port is: 9090, which seems to work.
2013-02-20, 16:44
Hello xbmc users
I have a problems getting xbmc on imon to work. i've been reading and trying many things on this forum and still don't have it working on my lcd!
I hope you can help me. i think i have the wrong version off xbmconimon i'v so can you tell me with 1 i need and were i can find it.
this the error i get from the log file:
XbmcOniMon.exe Error: 0 : 02/20/2013 15:34:27 [XBMC] Could not open a connection to XBMC
XbmcOniMon.exe Error: 0 : ArgumentNullException: Value cannot be null.
Parameter name: value
at Newtonsoft.Json.Linq.JToken.EnsureValue(JToken value)
at Newtonsoft.Json.Linq.JToken.op_Explicit(JToken value)
at XBMC.JsonRpc.XbmcPlayer.GetActivePlayers(Boolean& video, Boolean& audio, Boolean& picture, Int32& id)
at iMon.XBMC.XbmcHandler.xbmcConnected(Object sender, EventArgs e)
at XBMC.JsonRpc.XbmcJsonRpcConnection.onConnected()
at XBMC.JsonRpc.XbmcJsonRpcConnection.Open(Int32 jsonPort)
here are my settings so far:
case: Moneual moncaso 932
system: windows 7 prof 64 bit servie pack 1
xbmconimon by parsley v0.1.9.5
IMON MANAGER ver 8.12.1202
IMON F/W Version
IMON Firmwire ver 0x3416 7" touch lcd
xbmc uncheckt in frontvieuw manager read that that will do the thrik
XBMC 10.1 Git: e9e9099 compiled mar8 2011
I expliciet choose for this version because of the api settings in later versions of xbmc
xbmc is connected with i net at port 8080 and working the password is the same in xbmconimon and even treid it with out password
ip adres matches the one you can see in xbmc settings. it's also no firewall isu because i hav
xbmc remote working using the same config.
the only thing i have doubt about is the utp port 9090 becaeuse i cant find it in xbmc.
i've anyonme can help me that would be realy great.
IMON F/W Version
2013-02-20, 16:53
XBMConImon does not work with the colour touchscreen LCD's by Soundgraph. It only works with the older Monochrome letterbox style LCD's.
2013-02-21, 13:59
Hi, i am using Frodo over W7-64bits and its works except time played and time ramaining bars (up and down in lcd panel). It works before, but now it doesn't appears.
I just unmark XBMC on imon and configure XbmcOniMon. ¿Any idea or suggestion?
Thanks in advance !
Thanks in advance !
2013-02-21, 15:08
2013-02-25, 11:10
Hi
I recently started to have problems.
I added the plugin for the scraper of the film (MyMovies.it e Movieplayer.it) and from that moment every time I start the execution of a film XBMConIMON crashed.
the problem is repeated with any movie (DIVX, MKV ecc).
If i start XBMConIMON after start movie work correctly.
2013-02-25, 13:41
(2013-02-25, 11:10)xblastx Wrote: [ -> ]Hi
If your using BlackMan's 0.1.9.5 version, you may want to see here:
http://forum.xbmc.org/showthread.php?tid...pid1279364
2013-02-26, 09:15
(2013-02-25, 13:41)gibxxi Wrote: [ -> ](2013-02-25, 11:10)xblastx Wrote: [ -> ]Hi
Hi
thanks a lot, i change the version of XBMConIMON, after some checks all work correctly.
2013-02-27, 19:14
Hello, i have the same problem, as soon as it connects to xbmc i get framework error.
xbmconimon folder is right under c:
latest imon
xbmconimon 0.1.4
win 8 64
thanks in advance for help
latest imon
xbmconimon 0.1.4
win 8 64
2013-02-28, 10:07
You need to install older version of .net frame work like 3.5 becuase Windows 8 has only .net 4.5 and older versions are not installed by default. http://msdn.microsoft.com/en-us/library/hh506443.aspx
If you have Windows 8 installation disk, you can install .net offline without connecting to the internet.
