2013-06-28, 08:01
With the latest nightlies, xbmconimon is not working. I tested a previous version installed in another folder and it works. After closing this version and start the nightly, xbmconimon works.
(2013-06-03, 18:29)ck2012 Wrote: [ -> ](2013-05-19, 14:58)baijuxavior Wrote: [ -> ](2013-05-14, 18:34)ck2012 Wrote: [ -> ]Awesome thank you. My scrolling works fine for news and what not via Imon. When i fire up xbmconimon all features work except for the continuous scrolling. I dont see any setting for scrolling in xbmconimon.
If you could let me know your settings and versions of xbmc, imon and xbmconimon maybe i can figure it out.
I'm so close!
My Setup - Antec Fusion Remote LCD, iMON Manager V 8.12.1202, XBMConIMON V0.1.9.5 by parslej.
Still does not work. We have the same versions of software too. Would it matter that mine is an antec fusion black and yours is a antec fusion remote? I think the only difference is that remote has remote no ps and black has no remote and ps. I tried a few different file names and got nowhere.
All i want is the file name to repeat over and over again.
so frustrating.
(2013-06-30, 09:32)zep123 Wrote: [ -> ]I figured it out. After spending an hour or two at familiarizing myself with the code (the most recent version is: https://github.com/BlackMan82/xbmc-on-imon and https://github.com/BlackMan82/xbmc-jsonrpc-sharp by BlackMan82), I discovered this post by Montellese: http://forum.xbmc.org/showthread.php?pid...3pid723806
This second port (which notifies XBMConiMon of state changes) can be configured via the advancedsettings.xml:
<jsonrpc>
<tcpport>9090</tcpport>
</jsonrpc>
For some reason, it was not set to 9090 by default for me. Everything seems to be working fine now with version 13 alpha 4
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: String reference not set to an instance of a String.
Parameter name: s
at System.DateTimeParse.Parse(String s, DateTimeFormatInfo dtfi, DateTimeStyles styles)
at XBMC.JsonRpc.XbmcGeneral.get_BuildDate()
at iMon.XBMC.XBMC.xbmcConnectingFinished(IAsyncResult ar)
at iMon.XBMC.XBMC.<>c__DisplayClass4.<xbmcConnectingFinished>b__2()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5472 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
XbmcOniMon
Assembly Version: 0.1.4.0
Win32 Version: 0.1.4.0
CodeBase: file:///C:/Program%20Files%20(x86)/XbmcOnImon/XbmcOniMon.exe
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
iMonDisplayApiWrapperSharp
Assembly Version: 0.1.0.7
Win32 Version: 0.1.0.7
CodeBase: file:///C:/Program%20Files%20(x86)/XbmcOnImon/iMonDisplayApiWrapperSharp.DLL
XBMCJsonRpcSharp
Assembly Version: 0.1.0.2
Win32 Version: 0.1.0.2
CodeBase: file:///C:/Program%20Files%20(x86)/XbmcOnImon/XBMCJsonRpcSharp.DLL
System.Configuration
Win32 Version: 2.0.50727.5473 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Newtonsoft.Json.Net20
Assembly Version: 3.5.0.0
Win32 Version: 3.5.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/XbmcOnImon/Newtonsoft.Json.Net20.DLL
