2013-08-05, 00:44
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
2013-08-06, 14:52
Does anyone still work on this program because i really could do with a bit of help on my error. I have the progam up and running and everything seems to display right on my HTPC screen but after scrolling through movies, tv, music and so on i get an error that says XBMC on IMON Display has stopped working as on the picture below.
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: xbmconimon.exe
Problem Signature 02: 0.1.9.5
Problem Signature 03: 4f881829
Problem Signature 04: Newtonsoft.Json.Net20
Problem Signature 05: 3.5.0.0
Problem Signature 06: 4c66ae5f
Problem Signature 07: 289
Problem Signature 08: a9
Problem Signature 09: Newtonsoft.Json.JsonReader
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 2057
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=1...cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
I have the xbmc on imon log below
http://pastebin.com/UTkXk6PZ
Stopped working
Problem signature:
Locale ID: 2057
2013-08-06, 17:40
Did You Try this Version?
http://www.filedropper.com/imon-on-xbmc-by-parslej
1.9.5 by Parslej
It works great with Frodo in my system (win 7 32bit \ Frodo 12.2 Stable)
1.9.5 by Parslej
2013-08-07, 16:44
(2013-08-06, 17:40)tomer953 Wrote: [ -> ]Did You Try this Version?
1.9.5 by Parslej
Thanks for the link my friend, so far no error with this version.
2013-08-24, 17:06
Hello guys!
i have a M10 Case by origen ae like a guy a few pages bevor. I have tried the version from the first psot - no luck - every time framework error when xbmc is starting. The I have tried parslej's version and it works for me (it's a VFD iMon).
The only pity thing is the missing scroll feature. The Display can display scrilling text like a charm but not with xbmc at the moment And there is a little error: everytime I use %duration% Tag the Display shows only a "0" (zero). If we can get both to work it would be great!
I'm running Windows 7 SP1 64-bit with Frodo. Latest iMon and this imon on xbmc by parslej version above. I havn't installed any .net Framework by myself.
2013-08-25, 15:30
Have anyone managed to get the parslej version to show the pvr information correctly?
In my setup (Frodo 12.2) it works perfectly with music, videos, etc. but when watching tv, it usually only shows the epg info of the first program when starting live-tv. When I change the channel, display doesn't update. The log file shows following lines when starting live-tv
XbmcOniMon.exe Information: 0 : 08/25/2013 16:12:11 [XBMC] Trying to identify Unhandled type of media as movie
XbmcOniMon.exe Error: 0 : 08/25/2013 16:12:11 [XBMC] EXCEPTION in XbmcMovie.FromJson()!!!
XbmcOniMon.exe Error: 0 : ArgumentException: file
at XBMC.JsonRpc.XbmcMovie..ctor(Int32 id, String thumbnail, String fanart, String file, String title, String genre, Int32 year, Double rating, String director, String trailer, String tagline, String plot, String outline, String originalTitle, String lastPlayed, Int32 duration, Int32 playCount, String writer, String studio, String mpaa)
at XBMC.JsonRpc.XbmcMovie.FromJson(JObject obj, JsonRpcClient logger)
XbmcOniMon.exe Information: 0 : 08/25/2013 16:12:11 [XBMC] Result is null!!!
If any of the xbmc-on-imon developers are reading this, would it be a hard job to add better pvr information support? It would be perfect if you could choose what pvr info to show (channel, program info etc.).
2013-08-28, 11:48
...Not only that, the latest available version (for LCD) often hangs and takes up 80% CPU time on my Athlon X2 4850e when closing XBMC to desktop. My guess is XbmcOniMon is unaware XBMC has quit and is still attempting to communicate via the (now nonexistent) JSON API.
2013-08-29, 11:15
Yeah, I noticed too that sometimes it hangs in the background and also if the xbmc-on-imon is running before xbmc is started, sometimes it doesn't work at all until restarted. I solved the problems simply by making eventghost close xbmc-on-imon when quiting xbmc and starting it again with a slight delay when xbmc is started.
2013-09-05, 00:16
Hi all,
After passing on my thanks for the work that some people have gone to here to make my VFD no longer redundant, I have the following question...
I have an imon VFD, win8 (x64) xbmx 12.2 and net frameworks 2, 3, 3.5 and 4.5
I have got xbmc-on-imon 0.1.9.5 working as released no problems, however...
Has anyone got the Cdenfert version working with a similar setup? (I would really like to take advantage of the two lines of text and scrolling...)
When I replace the XBMCJsonRpcSharp.dll with Cdenferts version, xbmc-on-imon will no longer work (windows closes it with one dll i found or I get a runtime error with the other dll, both dlls found from a cdenfert post back awhile))
Any help would be greatly appreciated.
Also, whilst a few years ago Montellese mentioned that there is a mythical list somewhere of the type of entries you can put into the display lines (EG %Season% etc etc) I can't find this list anywhere... In particular I am after current running time (as opposed to duration)
Thanks in advance!
Thanks in advance!
2013-09-26, 09:22
1.9.5 by Parslej
Hey Guys,
could someone please re-upload the parslej version, as the filedropper version is not longer downloadable.
Although the "normal" 1.9.5 version is working with my Imon VFD, i can't make it show a progress bar and as i understood some previous postings this is possible with the parslej version.
Thanks for your help!
Greetz
2013-10-01, 23:56
Is there a way to get this working on the old Antec Fusion case (the silver one without remote)? I suspect the parslej version might do the trick but I can't confirm since it's not available any more.
2013-10-06, 16:23
2013-10-07, 02:36
(2013-10-01, 23:56)realnsd Wrote: [ -> ]Is there a way to get this working on the old Antec Fusion case (the silver one without remote)? I suspect the parslej version might do the trick but I can't confirm since it's not available any more.
Anybody?
2013-10-13, 11:02
Hello,
I made some fixes for FRODO. It's a VFD only version. If someone could test it.
http://www.mediafire.com/download/ud73e9....v1.0.4.7z
2013-10-13, 21:16
(2013-10-13, 11:02)cdenfert Wrote: [ -> ]Hello,
can't get it to connect to either xbmc or the vfd
