2014-02-04, 00:48
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
2014-02-04, 13:13
can someone help me out?
i have a Thermaltake DH-102 case with a imon touch screen..
i tried everything but i can't get the screen to work with xbmc... it shows nothing or it shows 000.000.00/ 000.000.00 (something like that)
i am a newb so don't be to hard on me
Edit: the imon screen is now connected in xbmctoimon but it keeps saying Unkown error in imon.. and i can't intialize it to imon
2014-02-04, 14:18
(2010-10-31, 22:44)s1mp3 Wrote: [ -> ]I'm still having problems with unknown IMON error. I have re-installed IMON (latest beta) and have installed Xbmc Dharma beta4.
Here is my debug log.
Quote:31.10.2010. 21:32:20 [GUI] Settings successfully applied to the GUI
31.10.2010. 21:32:20 [GUI] Setting up iMON
31.10.2010. 21:32:20 [GUI] Setting up XBMC connection to 192.168.2.6:80
31.10.2010. 21:32:20 [GUI] Auto-connecting to XBMC at startup
31.10.2010. 21:32:20 [XBMC] XbmcJsonRpcConnection.IsAlive
31.10.2010. 21:32:20 [GUI] Asynchronous starting to connect with XBMC
31.10.2010. 21:32:20 [XBMC] Opening a connection to XBMC
31.10.2010. 21:32:20 [XBMC] XbmcJsonRpc.Ping()
31.10.2010. 21:32:20 [XBMC] Calling JSON RPC method "JSONRPC.Ping"...
31.10.2010. 21:32:20 [XBMC] JSON RPC call: {
"jsonrpc": "2.0",
"method": "JSONRPC.Ping",
"id": 1
31.10.2010. 21:32:20 [XBMC] JSON RPC response: {
"id" : 1,
"jsonrpc" : "2.0",
"result" : "pong"
31.10.2010. 21:32:20 [XBMC] XbmcPlayer.GetActivePlayers()
31.10.2010. 21:32:20 [XBMC] Calling JSON RPC method "Player.GetActivePlayers"...
"jsonrpc": "2.0",
"method": "Player.GetActivePlayers",
"id": 2
"id" : 2,
"jsonrpc" : "2.0",
"result" : {
"audio" : false,
"picture" : false,
"video" : false
31.10.2010. 21:32:20 [XBMC Handler] Start working
31.10.2010. 21:32:20 [XBMC Handler] Update
31.10.2010. 21:32:20 [XBMC Handler] Displaying Idle
31.10.2010. 21:32:20 [Display Handler] Setting text to "XBMC"
"jsonrpc": "2.0",
"id": 3
"id" : 3,
"jsonrpc" : "2.0",
"result" : "pong"
31.10.2010. 21:32:20 [GUI] Connection with XBMC established
31.10.2010. 21:32:20 [XBMC] XbmcGeneral.BuildVersion
31.10.2010. 21:32:20 [XBMC] XbmcSystem.GetInfoLabel(System.BuildVersion)
31.10.2010. 21:32:20 [XBMC] Calling JSON RPC method "System.GetInfoLabels"...
"jsonrpc": "2.0",
"method": "System.GetInfoLabels",
"params": [
"System.BuildVersion"
"id": 4
"id" : 4,
"jsonrpc" : "2.0",
"result" : {
"System.BuildVersion" : "10.0-beta4 r35067"
31.10.2010. 21:32:20 [XBMC] XbmcGeneral.BuildDate
31.10.2010. 21:32:20 [XBMC] XbmcSystem.GetInfoLabel(System.BuildDate)
"jsonrpc": "2.0",
"params": [
"System.BuildDate"
"id": 5
"id" : 5,
"jsonrpc" : "2.0",
"result" : {
"System.BuildDate" : "Oct 28 2010"
31.10.2010. 21:32:20 [GUI] Initializing iMON
31.10.2010. 21:32:20 [iMON] IMON_Display_IsInited()
31.10.2010. 21:32:20 [iMON] IMON_Display_Init(197518, 37428)
31.10.2010. 21:32:20 [iMON] Message received: PluginFailed(512)
31.10.2010. 21:32:20 [iMON] ERROR Interpreting init result error type: Unknown
31.10.2010. 21:32:20 [iMON] ERROR Error received: Unknown
31.10.2010. 21:32:20 [GUI] ERROR iMON reports an error of type Unknown
31.10.2010. 21:32:20 [GUI] Uninitializing iMON
31.10.2010. 21:32:20 [iMON] IMON_Display_Uninit()
Thank you for your work!
Finally my LCD on Silverstone CW03 will be useful
how did you get this to work?
2014-02-04, 14:44
never mind ... i got a much better program... Yatse
but thnx anyway
but thnx anyway
2014-02-04, 18:29
Hehe, I have also found out about Yatse, and been using it ever since.
2014-02-19, 20:14
Hello
I'm using Antec Remote Fusion Black HTPC with Imon LCD in front. The OS is Win 7 64-bit. Using XBMC 12.3.
I would like the lcd show the media information, but for the life of me, I just can't get the ImononXBMC to connect.
I inserted the correct IP -address (the same as XBMC's system shows it to be). The default port is 8080 and that same is in the XBMC settings as in HTTP proxy.
I'm using the rar-package linked to this forum couple pages back.
I'm lost. Could some please help.
2014-02-20, 07:28
Use the parslej version of xbmconimon. You also need to specify the tcpport in advancedsettings.xml. http://forum.xbmc.org/showthread.php?tid...pid1588545
2014-02-20, 10:59
Thanks baijuxavior!
After specifying the tcpport it connects but now XBMC on iMon in system tray is reporting "iMon is not responding. Please restart iMON Manager".
I've restarted several times, but nothing changes. Still any help?
2014-02-20, 12:27
Are you using the parslej version of xbmconimon? http://www.share-online.biz/dl/13MP39UMIJ. Also read this thread http://forum.xbmc.org/showthread.php?tid...pid1590451. Post#786 . Removing the username helped him.
2014-02-20, 21:15
2014-02-20, 22:45
(2014-02-20, 12:27)baijuxavior Wrote: [ -> ]Are you using the parslej version of xbmconimon? http://www.share-online.biz/dl/13MP39UMIJ. Also read this thread http://forum.xbmc.org/showthread.php?tid...pid1590451. Post#786 . Removing the username helped him.
Yes useina the parslej-version. Will try removing the username frm the addon.
2014-02-26, 12:47
hi,
it seems that this project is dead , or ??
but i still hope that some 1 will come and continue it
2014-03-06, 21:27
Hello,
Do you already have an imon version that works with Gothem Beta 1
2014-03-07, 03:59
The parslej version works with Gotham.
2014-03-07, 06:55
Yes, the old nightly builds, but from the Beta 1, it no longer works only
