Full Version: XBMC on iMON Display (LCD / VFD) for Windows
working fine with 8.1 and Gotham-VFD
(2014-04-22, 16:12)baijuxavior Wrote: [ -> ]^^ Which version of xbmconimon are you using? Try the parslej version. It is working fine in my Gotham system.
I'm using this one http://sourceforge.net/projects/xbmc-on-imon/
Where do I get the parslej version?
Edit:
Found it, link http://www.share-online.biz/dl/13MP39UMIJ
Edit
Yep, that works perfectly
Thanks for the help Smile
Another one with windows 8.1 and gotham beta4 lcd
Not working Sad
EDIT: xbmc Gotham RC1
It's working
Another one with Windows 7 32 bits and gotham lcd
Not workingConfused
I have lcd and it works perfectly on Win 8, Gotham. Check if you have properly set the tcpip port in advancedsettings.xml file.
(2014-04-29, 14:16)PatOso Wrote: [ -> ]Another one with Windows 7 32 bits and gotham lcd
Not workingConfused
Check if you have activated the option: "Allow programs on other system to control xbmc"
That was my solution
Try it
Wink
(2014-04-29, 17:34)sendar Wrote: [ -> ]
Not workingConfused
Try it
Wink
Work, work, work,, LOL Rofl Simple and fast.....THX.
(2014-04-29, 15:45)baijuxavior Wrote: [ -> ]I have lcd and it works perfectly on Win 8, Gotham. Check if you have properly set the tcpip port in advancedsettings.xml file.
THANKS Wink
After 56 pages read, I still can't find a workaround Confused
Windows 7 64bit, Imon display VFD in a OrigenAE S16V case, latest version of iMON manager, followed the instructions literally (both for Parsley and older version), but all I can get on display is the remote input or Stop followed by 00.00.00.
Since I'm no newbie or digital analphabet, I'm getting a little frustrated. Any suggestion/alternative?
(2014-04-29, 19:17)pingone Wrote: [ -> ]After 56 pages read, I still can't find a workaround Confused
You've read the "README" file on how to configure iMON Manager?
Imon what version you have installed?
(2014-04-29, 22:57)PatOso Wrote: [ -> ]
Sure, of course. I've installed the latest release available on the Soundgraph site. BTW, I've found a little flaw in the readme: the text says "Now go to "iMON Utilities" --> "FrontView" and open the "Media Information" tab. Here you need to disable the "XBMC" option under "Available Player", but that option is in iMON manager, NOT in iMon utilities... Am I wrong?
(2014-04-29, 23:46)pingone Wrote: [ -> ]Sure, of course. I've installed the latest release available on the Soundgraph site. BTW, I've found a little flaw in the readme: the text says "Now go to "iMON Utilities" --> "FrontView" and open the "Media Information" tab. Here you need to disable the "XBMC" option under "Available Player", but that option is in iMON manager, NOT in iMon utilities... Am I wrong?
Yes, in iMON manager............
Path:
IMON manager< IMON utilities< Frontview<Media Information<Uncheck the box "XBMC".
Imon-on-xbmc-by-Parslej -v0.1.9.5 Beta April 13, 2012, Work for me in Thermaltake - DH202 Case
(2014-04-30, 00:37)PatOso Wrote: [ -> ]
Path:
Which version of iMON manager?
Same as me. I'm definitely stuck Confused
Since this plugin is so buggy and no longer developed I tried if the LCD smartie can be set up with the iMON displays. It actually works pretty well, I wrote some instruction if someone else want to try it.
http://forum.xbmc.org/showthread.php?tid=196145
