2015-01-18, 14:39
I reccomend clearing the default username/password in both XBMC/Kodi and XbmcOniMon when setting up, as it limits the number of potential points of failure. Once it's working, then re-assign the password/username combo if required.
Ports in my setup are 80 / 9090. It works as it should. Be mindful that the VFD and LCD are two different products, and Parslej's version only supports the LCD version, and likewise cdenfert's the VFD version. Both are forks of Montellese's / Blackman's original work on the utility.
I have said this before, but it's worth repeating; Disable the "XBMC Media Info" integration in the IMON Manager software, as XbmcOniMon replaces this functionality. IMON's built in support has been broken since at least Eden, and may conflict with XbmcOniMon when trying to connect. This option will be auto-enabled if you install the drivers/software with XBMC installed.
There is still an outstanding issue of XbmcOniMon pegging CPU usage to 100% sometimes when XBMC/Kodi quits. I think XbmcOniMon is not uninitializing properly when this occurs. It doesn't happen all the time, but enough to be annoying.
