Full Version: XBMC on iMON Display (LCD / VFD) for Windows
(2016-02-15, 01:26)Sleuth255 Wrote: [ -> ]json port settings need to be specified in advancedsettings.xml. You must have the jsonrpc tags in the xml file or xbmconimon will not connect unless you set the tcp port to the same value as the webserver port. However if you do this, json notifications won't be sent out and you will get no playing show info!
I am having the same issue as you described here. I can only connect when I set the TCP port to be the same as the webserver port, but then I get no show info.
I tried setting the port to '9090' which should be the default, and I tried setting it in the advancedsettings.xml to 9090 and still nothing.
Anyone have any ideas?
I'm using Kodi 15.2 and have both the perslej and margru versions of XBMC on iMon.
(2015-12-04, 07:06)MANswers Wrote: [ -> ]Imon for XBMC connects and initializes, but i cannot see the name of the movie, or for that matter anything on the lcd screen. it turns blank with no info. When i shutdown kodi, normal imon starts working fine.
I am on Jarvis.
I got the same issue from time to time.
In the program .net exceptions are caught, nut no natives are caught, causing some threads to crash from time to time.
I got the issues when playing songs that are longer then 20 min , but shorter then 1 hour, then the timespan.parse() method would crash.
If you got the same issue, when it crashes from time to time,you can my edited verion here.
I'm running Win7, x86, with Kodi 16
grtz,
Nick
(2016-04-03, 16:49)tobeychris Wrote: [ -> ]
Do you have advancedsettings.xml in the correct directory? One way to check this: Is xmbconimon saying its connected now that you have the tcp port changed to 9090?
(2016-04-17, 00:55)Kindt.Nick Wrote: [ -> ]
I am on Jarvis.
grtz,
Nick
Hello @Kindt.Nick,
Could you send me your edited version? I'm suffering the time to time crashes.
Thanks in advance!!
SETUP VFD (without disc icon)
I have 2 lines with the Title (with deffilement) the curent movie time ( >1:25:36 / 2:30:00) / or progress bar / or current time + progress bar
XbmcOnImon Version :
https://www.dropbox.com/s/fx1r64tugs1k4l....4.7z?dl=0
Cruz40Setup :
imon settings left alone
1st
Kodi
System-Services-Web server
settings
Allow remote control via http: enabled
port 9191 *these must match
username kodi
move off page to save settings
System-Services-Remote control
settings
Allow remote control by programs on other systems: enabled
close kodi
xbmc-on-imon settings
ip 127.0.0.1 port 9191 *these must match
username kodi
tcp port 9090
move on off page to save changes
I tried to get this working on Win10 x64 with Kodi and my Silverstone CW03 case which runs iMon to display on an LCD monitor. Whenever I start Kodi, XBMC on iMon crashes. I've tried a few different ports but still just get a crash. Does anyone have this working on similar hardware? And Win10? What settings should I have for kodi and XBMC on iMon?
(2015-08-26, 21:13)cruz40 Wrote: [ -> ]ok after hours of testing I have gotten it to work
Works on
Windows 10
Kodi 15.1
iMON Manager Version 8.12.1202
http://www.soundgraph.com/forums/showthread.php?t=9857
xbmc-on-imon v0.1.9.5
https://code.google.com/p/xbmc-on-imon/downloads/list
SETUP
1st
Kodi
settings
username kodi
settings
close kodi
username kodi
tcp port 9090
open kodi
will ask you to restart iMon manager
you have to do all the steps or xbmc-on-mon wont shutdown if you exit kodi
more xbmc-on-imon settings
control mode enable ( shows current highlighted item on LCD )
during playback disable
let me know if this works for you
Thanks for the info but this isnt working for me. I am using Win10 x64 and Kodi 15.2 if that makes any difference? Would a log output be useful?
(2016-05-29, 11:48)Jogga Wrote: [ -> ]SETUP VFD (without disc icon)
Cruz40Setup :
1st
Kodi
settings
username kodi
settings
close kodi
username kodi
tcp port 9090
Thanks, i tried ur script, and settings, and i was able to connect, but i am still not able to initialize Imon via XbmcOniMonVFD
I still do not see anything reflected from xbmc to vfd.
This used to work once upon a time, much before i had upgraded.. but is broken now.
Please guide.
Cruz40Setup :
1st
Kodi
settings
username kodi
settings
close kodi
username kodi
tcp port 9090
thanks it's works for me on kodi 16.1 windows 10 64 bits.
the only thing during a film, I have only the title shown. but not the current time or else.
just the first line indicate the name of the film
is there anything to do in order to see the progress time ?
thank you
For quite some time i got xbmconimon v0.1.9.5 working with kodi 16.1 . Works fine, i just wonder if anyone have it still working on kodi 17?
(2016-10-01, 11:06)ShinobiX9X Wrote: [ -> ]For quite some time i got xbmconimon v0.1.9.5 working with kodi 16.1 . Works fine, i just wonder if anyone have it still working on kodi 17?
Still works for me on Kodi 17 Beta 3.
hello,
could someone publish thi package : iMON Manager Version 8.12.1202 ??
The link is dead.
thanks
Does it also work with Kodi from the windows store?
