Hi all.
I've been using Kodi in the form of OpenELEC & LireELEC for some years now. I'm trying to switch to a Windows based system now and would like to use this addon.
I've installed it and got it displaying but I only have the "Title" line visible. I would very much like to get the progress bar working but I can't figure out how to do it.
I've read through every page here but could not see how to do it. Did I miss it?
Could someone please explain it or show me a link to the info.
Cheers
Cheers for that. I left OE due to slow development and started using LE.
Guessed it was only a matter of time before OE died as all the good developers went to LE.
I'm now wanting to switch to Windows based system as Linux based is difficult for me to work with. I have basic Linux knowledge but much better with Windows. I wasn't happy with some areas of the LE system and didn't have the knowledge to change them myself.
An update on this.
Looking further into the settings, I can see an option for "show progress". It is ticked but grayed out so I cannot adjust this setting. I'm using the 0.1.9.5 version. I tried the 0.1.4 version but would only get an exception error when it tried to connect to Kodi.
Hello dear community,
I've already tried to get a useful result on the search function. :
Either there is nothing or I'm too stupid; (
Please forgive if I have not found it.
After a few years, I'm now off for 4K, etc. of my Rasp and again switched to a Windows box.
Is there anyone who has gotten this display (Silverstone CW3) running with media information from Kodi18 ?
silverstonetek.com/product.php?pid=161&area=en
About a tip, I would really very, very grateful. : D
Best regards
Christian
Bad news. My HTPC had to be reinstalled so I decided to switch to Leia (RC 3). This led to many hours of frustration trying to get the display to work, sometimes it worked, most of the time XBMConImon seemed to crash according to the logs and could only come up with the idle text.
I have a 64 bit system so I had installed Leia 64, but later tests with the 32 bit version didn’t improve matters. I finally decided to switch back to Krypton and the display is once again working like a charm.
My display is the 310 something used in the Originae S10, so VFD running Win 10 pro 64. The software used is 1.4.0 by Montelesse, tried all other iterations as well.
Should anyone have a solution, I would be most grateful as it now seems I will be stuck with Krypton forever.
It happens to me exactly the same as you, same vfd screen, same version of kodi.
I need a solution, Thanks.
The same problem with Kodi 18.....
hopefully this error have solution!!
Thanks a lot
Could not find it in (there are a lot of pages).
But I have Kodi 17.6 (Zephyr) on my Windows 10 64bit htpc with iMon Manager 8.12.1202.
I got the VDF display working at startup, but it crashes when I start to play a song. When opening XBMConiMon again it shows the title informatie. But again crashes when choosing another song.
The strange thing is that when I play a whole album or playlist it keeps on working (till I chose another album or song)?
Tried a lot with the settings, but can't find the problem.
Any tips on this? Thanks a lot in advance...
PS:
I can't turn of XMBC in the Imon Manager as the ReadMe says you should do, it's greyed out
When watching live tv, initially I get the episode name showing, but it doesn’t change when the next show starts, this feature worked fine with WMC. Anyone know why this doesn’t work?
Hey,
did any of you guys with an iMon VFD had luck with getting it to seamless work with Kodi 18?
Mine is partly working and it shows me a progress bar from the movie/tv show i'm watching but only the second one in my playback playlist. Initially it gets stuck on the last menu item i was before i started playback.
Hopefully anyone got a working solution :-)
(2018-12-29, 21:45)Brigitte Wrote: [ -> ]Bad news. My HTPC had to be reinstalled so I decided to switch to Leia (RC 3). This led to many hours of frustration trying to get the display to work, sometimes it worked, most of the time XBMConImon seemed to crash according to the logs and could only come up with the idle text.
have you found any workaround for this problem?
It may be XBMCJsonRpcSharp.dll is having issue. I did a quick update on this file validating incoming JSON from KODI because I found KODI v18 sometime send broken JSON format and will crash the plugin.
Download it and replace the one in your Imon-on-xbmc-by-Parslej folder
(2020-12-07, 09:48)ckegg Wrote: [ -> ]It may be XBMCJsonRpcSharp.dll is having issue. I did a quick update on this file validating incoming JSON from KODI because I found KODI v18 sometime send broken JSON format and will crash the plugin. Download it and replace the one in your Imon-on-xbmc-by-Parslej folder
Sorry if these questions have already been asked I'm currently using an Antec Fusion Case (Black) not sure if it has LCD or VFD
Edition Windows 10 Pro
Version 20H2
Installed on 12/7/2019
OS build 19042.685
Experience Windows Feature Experience Pack 120.2212.551.0
Kodi 18.8..
What are the steps as I have tried getting the display to work as well as Imon and this seems stressful ?
Any help greatly appreciated as I'm losing my hair...
I
Hi, thanks a lot for your effort. Unfortunately I have a Soundgraph VFD Display, so i'm not using the parslej version. Can you tell me how to fix it by myself or help me to get this fix to work with other xbmc-on-iMon versions?
