2010-10-28, 10:08
i would like to enable power-on from the mce remote to my system.
i stumbled into this issue when troubleshooting another issue following an update to the dharma beta 3
reading through the thread "No resume form standby with vista remote after 2.6.32-23 #37 Kernel version", it seemed that i wasnt running an appropriate kernel level.
infact, i was still running Ubuntu Karmic (9.10). so first step was to upgrade to Ubuntu Lucid. 10.04.1 was available when i attempted this through Distribution Manager. This completed successfully, and required subsequent updates to nVidia drivers, ALSA and Lirc to newer versions running on Lucid.
POwer-off from remote works within XBMC, as it did before any upgrade work.
i followed the following threads for info as to how to set up wake-on-usb:
Ubuntu Suspend / Wake
Enable Wake-On-Device
However, i am unable to power-on the device still, even though my kernel is at an appropriate level.
my config is as follows:
Motherboard: ASUS P5N7A-VM. XBMC connected to HDTV via HDMI. Recieve audio via HDMI too. MCE Remote plugged into rear USB port. Ubuntu Lucid (10.04.1)
lsusb
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 0471:0815 Philips eHome Infrared Receiver
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 15c2:0038 SoundGraph Inc.
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 2040:8400 Hauppauge
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lspci | grep US
00:04.0 USB Controller: nVidia Corporation MCP79 OHCI USB 1.1 Controller (rev b1)
00:04.1 USB Controller: nVidia Corporation MCP79 EHCI USB 2.0 Controller (rev b1)
00:06.0 USB Controller: nVidia Corporation MCP79 OHCI USB 1.1 Controller (rev b1)
00:06.1 USB Controller: nVidia Corporation MCP79 EHCI USB 2.0 Controller (rev b1)
01:05.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 62)
01:05.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 65)
cat /proc/acpi/wakeup
Device S-state Status Sysfs node
UAR1 S4 disabled pnp:00:0b
SMB0 S4 disabled pci:0000:00:03.2
USB0 S4 disabled pci:0000:00:04.0
USB2 S4 disabled pci:0000:00:04.1
US15 S4 enabled pci:0000:00:06.0
US12 S4 disabled pci:0000:00:06.1
NMAC S5 enabled pci:0000:00:0a.0
PBB0 S4 disabled pci:0000:00:09.0
HDAC S4 disabled pci:0000:00:08.0
XVR0 S4 disabled pci:0000:00:0c.0
XVR1 S4 disabled
P0P5 S4 disabled
P0P6 S4 disabled pci:0000:00:15.0
P0P7 S4 disabled pci:0000:00:16.0
P0P8 S4 disabled
P0P9 S4 disabled
i am not sure why the USB devices are reporting as S-state "S4". maybe this is causing the issue?
i have written the "echo USB0 > /proc/acpi/wakeup" into /etc/rc.local and confirm this seems to work as expected. i have tried all 4 listed USB devices to make sure i have the correct port specified.
uname -r -v
2.6.32-25-generic-pae #45-Ubuntu SMP Sat Oct 16 21:01:33 UTC 2010
XBMC
team-xbmc-svn repository running Dharma Beta 3
Lirc
0.8.6-0ubuntu4.1
the "No resume form standby with vista remote after 2.6.32-23 #37 Kernel version" thread mentions to initially downgrade to 2.6.32-22 to restore functionality. later in the thread, people indicate that 2.6.32-25-44 onwards work too. could this be related?
can anyone confirm this motherboard is compatible?
can anyone help?
i hope so...
jingo_man
lsusb
lspci | grep US
XVR1 S4 disabled
P0P5 S4 disabled
P0P8 S4 disabled
P0P9 S4 disabled
uname -r -v
XBMC
Lirc
0.8.6-0ubuntu4.1
can anyone help?
i hope so...
jingo_man
