Full Version: XBMC crashes at exit
Hello,
when i exit xbmc, i always get a coredump / segfault.
This is, what on the console comes:
xbmc
params.c:OpenConfFile() - Unable to open configuration file "/root/.smb/smb.conf":
        No such file or directory
params.c:OpenConfFile() - Unable to open configuration file "/root/.smb/smb.conf.append":
        Datei oder Verzeichnis nicht gefunden
there is no soundcard
ALSA lib pcm.c:7245:(snd_pcm_recover) underrun occured
Segmentation fault (core dumped)
Crash report available at /root/xbmc_crashlog-20101028_132402.log
the full log xbmc_crashlog-20101028_1324.log can be found here: http://paste.debian.net/98475/
A grep -i error xbmc_crashlog-20101028_1324.log gives:
13:23:03 T:140233859688480 M:1542623232   ERROR: Unable to load libcrystalhd.so.2, reason: libcrystalhd.so.2: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
13:23:04 T:140233859688480 M:1535115264   ERROR: GLX: Same window as before, refreshing context
13:23:04 T:140233693718288 M:1527447552   ERROR: JSONRPC Server: Failed to bind serversocket
13:23:48 T:140233859688480 M:1508249600   ERROR: PulseAudio: Waited for the Context but it failed
13:23:48 T:140233859688480 M:1508249600   ERROR: PulseAudio: Failed to create context
13:23:49 T:140233859688480 M:1508229120   ERROR: PulseAudio: Waited for the Context but it failed
13:23:49 T:140233859688480 M:1508229120   ERROR: PulseAudio: Failed to create context
What is going wrong?
Thanks for Help
install gdb, crash it again and pastebin that crashlog.
spiff Wrote:install gdb, crash it again and pastebin that crashlog.
for what stands gdb?
ps - ah ok:"Der GNU-Debugger"
it crashes deep inside the fglxr drivers :/
ah. so i had to buy an vdpau/nvidia-card?
not necessarily, maybe newer / older drivers may help. but it's sort of outside our control since those drivers are closed binaries...
Someone found a working version of fglrx driver that solve this issue?
Hi i have the same problem With Nvidia, tried 3 differant drivers...
