Full Version: [LIVE] Dharma 3 - not resuming after standby
Resuming with power button worked fine with Dharma 2. Now with Dharma 3 it doesn´t. PC will wake up and may only show static cursor in the left upper corner, but that´s all. It´s not even possible to ssh into the PC. Any idea what could cause this?
xbmc.old.log: http://pastebin.com/W1HCyPnE
if ssh doesnt work either it probably isnt an xbmc bug as such. seems you aren't resuming properly (hence sshd not coming back)
what does /var/log/messages say just before and after your suspend/resume?
At 21:49 I hit put PC to suspend. It seems that there´s nothing in the log when I try to resume. 21:50:49 is time when I forced the machine to shut down and restarted.
Oct 28 21:49:08 XBMCLive kernel: [   40.577766]  [<c014c6e2>] warn_slowpath_common+0x72/0xa0
Oct 28 21:49:08 XBMCLive kernel: [   40.577778]  [<c03536e2>] ? vsnprintf+0x3f2/0x410
Oct 28 21:49:08 XBMCLive kernel: [   40.577788]  [<c03536e2>] ? vsnprintf+0x3f2/0x410
Oct 28 21:49:08 XBMCLive kernel: [   40.577801]  [<c014c72a>] warn_slowpath_null+0x1a/0x20
Oct 28 21:49:08 XBMCLive kernel: [   40.577812]  [<c03536e2>] vsnprintf+0x3f2/0x410
Oct 28 21:49:08 XBMCLive kernel: [   40.577826]  [<c035378a>] snprintf+0x1a/0x20
Oct 28 21:49:08 XBMCLive kernel: [   40.577850]  [<f888564d>] snd_print_pcm_bits+0x5d/0x80 [snd_hda_codec]
Oct 28 21:49:08 XBMCLive kernel: [   40.577877]  [<f888e7f7>] hdmi_show_short_audio_desc+0xf7/0x100 [snd_hda_codec]
Oct 28 21:49:08 XBMCLive kernel: [   40.577892]  [<c035378a>] ? snprintf+0x1a/0x20
Oct 28 21:49:08 XBMCLive kernel: [   40.577916]  [<f888e85f>] snd_hdmi_show_eld+0x5f/0xa0 [snd_hda_codec]
Oct 28 21:49:08 XBMCLive kernel: [   40.577942]  [<f888eb6c>] ? snd_hdmi_get_eld+0x29c/0x2d0 [snd_hda_codec]
Oct 28 21:49:08 XBMCLive kernel: [   40.577958]  [<f8aa6706>] hdmi_unsol_event+0x106/0x110 [snd_hda_codec_nvhdmi]
Oct 28 21:49:08 XBMCLive kernel: [   40.577973]  [<c013f0c3>] ? finish_task_switch+0x43/0xc0
Oct 28 21:49:08 XBMCLive kernel: [   40.577996]  [<f8885106>] process_unsol_events+0x56/0x70 [snd_hda_codec]
Oct 28 21:49:08 XBMCLive kernel: [   40.578010]  [<c016399e>] run_workqueue+0x8e/0x150
Oct 28 21:49:08 XBMCLive kernel: [   40.578033]  [<f88850b0>] ? process_unsol_events+0x0/0x70 [snd_hda_codec]
Oct 28 21:49:08 XBMCLive kernel: [   40.578047]  [<c0163ae4>] worker_thread+0x84/0xe0
Oct 28 21:49:08 XBMCLive kernel: [   40.578060]  [<c0167a60>] ? autoremove_wake_function+0x0/0x50
Oct 28 21:49:08 XBMCLive kernel: [   40.578072]  [<c0163a60>] ? worker_thread+0x0/0xe0
Oct 28 21:49:08 XBMCLive kernel: [   40.578083]  [<c01677d4>] kthread+0x74/0x80
Oct 28 21:49:08 XBMCLive kernel: [   40.578094]  [<c0167760>] ? kthread+0x0/0x80
Oct 28 21:49:08 XBMCLive kernel: [   40.578107]  [<c0104087>] kernel_thread_helper+0x7/0x10
Oct 28 21:49:08 XBMCLive kernel: [   40.578115] ---[ end trace a882e30d0ed6f168 ]---
Oct 28 21:49:08 XBMCLive kernel: [   40.578124] HDMI: supports coding type LPCM: channels = 2, rates = 44100 48000 88200 176400 192000 384000, bits = 16
Oct 28 21:49:08 XBMCLive kernel: [   40.578141] HDMI: supports coding type LPCM: channels = 6, rates = 44100 48000 88200 176400 192000 384000, bits = 16
Oct 28 21:49:08 XBMCLive kernel: [   40.578157] HDMI: supports coding type LPCM: channels = 8, rates = 44100 48000 88200 176400 192000 384000, bits = 16
Oct 28 21:49:08 XBMCLive kernel: [   40.578171] HDMI: supports coding type AC-3: channels = 6, rates = 44100 48000 88200, max bitrate = 680000
Oct 28 21:49:08 XBMCLive kernel: [   40.578185] HDMI: supports coding type DTS: channels = 6, rates = 44100 48000 88200 176400 192000, max bitrate = 1536000
Oct 28 21:50:49 XBMCLive kernel: imklog 4.2.0, log source = /proc/kmsg started.
Oct 28 21:50:49 XBMCLive rsyslogd: [origin software="rsyslogd" swVersion="4.2.0" x-pid="648" x-info="http://www.rsyslog.com"] (re)start
Oct 28 21:50:49 XBMCLive rsyslogd: rsyslogd's groupid changed to 103
Oct 28 21:50:49 XBMCLive rsyslogd: rsyslogd's userid changed to 101
Oct 28 21:50:49 XBMCLive kernel: [    0.000000] Initializing cgroup subsys cpuset
Oct 28 21:50:49 XBMCLive kernel: [    0.000000] Linux version 2.6.32-25-generic ([email protected]) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #44-Ubuntu SMP$
Oct 28 21:50:49 XBMCLive kernel: [    0.000000] KERNEL supported cpus:
Oct 28 21:50:49 XBMCLive kernel: [    0.000000]   Intel GenuineIntel
