2010-10-31, 13:43
Hi there,
I'm running Dharma SVN from the Maverick PPA. I use the VNC Remote HippoRemote on my iPhone for XBMC.
HippoRemote has a template for XBMC which includes buttons for volume control. The volume down button sends a '-' and the volume up button sends a '+'. With versions prior to Dharma this worked flawlessly.
But since the Dharma upgrade turning the volume up by hitting '+' (on the keyboard or the remote) doesn't work anymore. Using '=' still works. Unfortunately I cannot not easily reconfigure the iPhone app to send '=' instead of '+'.
Is this keymap change intentionally?
