2010-10-31, 17:20
I can't seem to figure out the right way to name xml's that should take care of skinning add-ons.
For instance using:
script-GmailChecker-main.xml
works fine to include an xml in my skin that provides skinning support for that add-on.
But when I use try to do this for the big pictures script like this:
script-The Big Picture-main.xml
this won't work. I've tried several variations on this (no spaces, underscores, etc.). Both scripts have similar file system layouts.
So in short: should the name set in the addon.xml be used to name the xml?
For instance using:
