2010-11-01, 23:04
XBMC seems to have problems with certain transport stream files (DVB-T recordings). It first plays them just fine, but at some point, it just stops playing and returns to the menu. Also fast-forwarding often puts me back to the menu.
I guess that's due to DVB-T signal quality drop-offs, leading to somehow "buggy" recordings. I found some other posts describing this problem, but no solution other than "fix the files". Those recordings are only for one-time-viewing, so there's not much point in reencoding.
vlc can play those files just fine, it simply skips over the problematic parts, so I'm wondering if XBMC could do that too.
Thanks,
Carsten
Thanks,
Carsten
