Full Version: [LIVE] Install and LVM
Hi there,
So I invested in some hardware, downloaded the BETA 3 and started an adventure for creating a XBMC box n my old Sun Cobalt Qube3 housing.
After some problem with the SATA controller and disk recognition by the partitioner I bravely moved on installing the system on two 500Gb disks. I want the system to be set up mirroring the disk. As i found the RAID chip on my JetWay board is apparently a HOAX and is fake raid i moved on using LVM with the partitioners manual setup. So I created a EXT4, Extended and SWAP partition on both drives (as the guided partioner would do) and then created a Volume Group and Logical Volume for both the EXT4 and the SWAP partitition.
With that setup I proceeded the installation, which all worked fine and told me it was done after it was finished. A reboot was in order and I found myself staring at an error say:
ALERT! /dev/mapper/VG1-LV1 does not exist. Dropping to a shell.
And there it all ends again. Can someone please shed some light on this? I'm absolutely not a Linux user so maybe I'm going all wrong about it, but hey... just let me know.
