2010-11-04, 01:34
Ive just installed and exploring the world behind both linux and XBMC.
Im using XBMC 9.11
ATM i am attempting to install Aeon65.
Firstly i tried a tutorial that explained using the code (Ctrl+Alt+F2), typing something along the lines of using "git"
[as you can tell, im not the most knowledgeable user just yet.]
so as an alternative, i found and downloaded a program that would allow me to write to my ext2 in windows 7. and copied some other skins into F:\home\owner\.xbmc\skin
just to try it out. and they all work fine.
then i went and downloaded Aeon65 as a zip file from here:
https://github.com/pix/aeon/tree/pix65
now, it wasnt obvious to me that this source is missing the "skin.xml" file. and i found that out 200MB later.
therefore; my question.
can someone instruct a n00b how to install this skin and/or just the skin.xml file (i already have 200MB of files)
Im using XBMC 9.11
