Hi! I would like to delete / remove extra add-on repositiories from Add-on manager. When i right click on the repository, I do only see "force update" and similiar options -no options about removing. How do you remove unneeded addon repositiories within the XBMC?
hit 'i'. thought i added the damn context menu entry already, guess i forgot.
spiff Wrote:hit 'i'. thought i added the damn context menu entry already, guess i forgot.
Thankx for your super quick response. Now I'm able to remove those add-on repositories that I don't stand out anymore
Would be a great idea also to add a deletion function using the "c" context menu.
Thankx for the great JOB!
Hello,
can somebody help me. I removed unwanted repository, but addons from those repository remain in XBMC (they are not installed, but i can install them) Is there any way to "clean up" that.
In other words, I wan't to be able to see only add ons from repositorys i added.
thnx
Found the solution. Use at Your own risk!
Just rename file Addons.db to Addons-bkp.db found in:
C:\Users\%username%\AppData\Roaming\XBMC\userdata\Database
When next starting XBMC it will recreate addon.db The reason why rename not delete is if something goes wrong You can switch it back.
