Full Version: How to scrape & convert thumbnails?
I've been using the Aeon MQ skin for a while now, and I wanted to enrich the experience a bit. As aeon offers info panels with 4 thumbnails (!) I thought I would do a 'sample rescrape' using EMM and add 4 thumbnails for each movie.
The problem hereby is that the scraping process that xbmc uses for thumbnails is far from ideal. First off, it's scrapes on demand, so only when you access any particular thumbnails in xbmc. Second, there's only copying involved, so xbmc basically copies the thumbnail from your movie library to the cache. Especially the latter issue can be annoying. Because what do you do when want to resize your thumbnails?
So, is there a way I would be able to set how the thumbnails are scraped/converted?
(thanks for moving this thread moderator ;-))
