Full Version: [Linux][Dharma][Camelot] Camelot & Dharma, side-by-side
After dealing wit h Dharma+pulseaudio problems, I decided to use a Camelot 9.11 for now, which is playing all my videos with no problems. While keeping an eye on Dharma. Is there a way to have them two together?
So, here is a newbie part: Can I just move my Camelot to other place?
I.e., rename
/usr/share/xbmc/ and ~/.xbmc to
/usr/share/xbmc_camelot/ and ~/.xbmc_camelot.
And install Dharma 4. So I just call them by different links? How can I refer my Camelot to use different ~/.xbmc_camelot settings?
Or I shall use different users, so there are different /home/[user]/.xbmc while I only change /usr/share/xbmc?
Is there something else? Is it doable?
Thank you
Dharma is at RC1 now so go ahead and use that.
